Adding a Dynamic Image in the Custom Print Template
To add images from within Unifier to the Custom Print template:
  1. Create form fields in the .rtf file, corresponding to the following parameters:
    • <?variable@begin:uuu_p_urlF;(.//uuu_p_urlF)[1]?>
    • <?variable@begin:uuu_p_sessionIdF;(.//uuu_p_sessionIdF)[1]?>
    • <?variable@begin:uuu_p_companyRegistryF;(.//uuu_p_companyRegistryF)[1]?>
      The uuu_p_* is a predefined parameter in the data model.
  2. Right-click the dummy image, select Size, and provide the following value in the Description field of the AltText information for the image:
Description: url:{concat($uuu_p_urlF,'companyRegistry=',$uuu_p_companyRegistryF,'&sessionId=',$uuu_p_sessionIdF,'&id=',<BPIMAGE> )}
In the Description, you can access the image by entering the complete path to the image or by using .// to look for the image in the Data Model.
For example, in the preceding URL value, you must replace the <BPIMAGE> data element with the image file ID " k__<image element>" from the sample XML. See Sample XML Data for Custom Templates (Custom Prints and Reports).
If the Data Model includes multiple levels, you must add each level to the path; for example, use: .//<level1>/<level2>.../<BPIMAGE>
