Sending Cash Flow Values from Unifier to Oracle Primavera Cloud
To send cash flow values from Unifier to Oracle Primavera Cloud as needed, you must ensure that Primavera Cloud is up and running and that you receive the access token.
The following table shows the type of data that can be sent from cash flow to Primavera Cloud:
Planned Budget By Project only (defined in project) By CBS only (defined in project) By Summary CBS only (defined in project) By Project and By CBS or By Summary CBS (defined in project) By CBS and By Summary CBS (defined in project)
Baseline or any Derived Curve based on Baseline Type Only Summary row data Row data by Capital and Expense if there are CBS codes whose cost type is defined as Capital and Expense. Row data by Capital and Expense Only Summary row data Row data by Capital and Expense
Forecast or any Derived Curve based on forecast Type Only Summary row data Row data by Capital and Expense if there are CBS code whose cost type is defined as Capital and Expense. Row data by Capital and Expense Only Summary row data Row data by Capital and Expense
Actuals or any Derived curve based on Spends Type Only Summary row data Row data by Capital and Expense if there are CBS code whose cost type is defined as Capital and Expense. Row data by Capital and Expense Only Summary row data Row data by Capital and Expense
