Update Fund Consumption for CBS Level SOV (Auto-Order / Auto-Ratio)
PUT /ws/rest/service/v1/fund/sov/consumption/{project_number}
Purpose
To assign Funds to CBS in SOV of types "General Spends" & "Payment Applications".
Request Format
All parameters should be URL encoded.
Both input & output in JSON format in the body.
Sample Request For SOV Auto-Ratio
"data":{
"Purchase Orders" ( commit_bp_name ):{
"sov_type":"General Spends", ( optional )
"assignment_type":"SOV Auto-Ratio", ( optional )
"record_no":{
"PO-0002" ( SOV base record number ):{
"rows":[
"item#":"000010",
"cbs_code":"100~~101", ( optional )
"fund_assignment":[
"fund_code":"funding",
"fund_ratio":"40",
"status" : "Active" ( optional )
"fund_code":"State Funding",
"fund_ratio":"0"
"status" : "Active"
"fund_code":"Federal Funding",
"fund_ratio":"60"
"item#":"000020.00001",
"breakdown" : "BD1",
"cbs_code":"100~~102",
"fund_assignment":[
"fund_ratio":"100"
"PO-0001":{
"rows":[
"item#":"000010",
"fund_assignment":[
"fund_ratio":"100"
SOV Auto-Order
fund_assignment can be provided in two ways:
1)
"data":{
"Group_by_CBS_base_commit_bp" ( commit_bp_name ): {
"sov_type": "General Spends",
"assignment_type": "SOV Auto-Order",
"record_no": {
"uxfund20-0000" ( SOV base record number ): {
"rows": [
"item#": "000010",
"cbs_code": "100~~101",
"fund_assignment": [
"funding",
"State Funding",
"Federal Funding"
2)
"data":{
"Group_by_CBS_base_commit_bp": {
"record_no": {
"uxfund20-0000": {
"rows": [
"item#": "000010",
"fund_code" : "funding"
"fund_code" : "State Funding"
"fund_code" : "Federal Funding"
- The "item#" is mandatory, to uniquely identify row to be updated, in SOV sheet.
- For SOV Auto-Order, if only one fund_code is provided in input without fund_ratio, the default 100% will be applied to that fund_code.
- SOV sheets configured to be funded from Commit Fund Sheet, will not get updated from this update call.
- To perform this call, the Integration user needs to have the Get permission under Cost CBS Services permission (under "User Administration in Company Admin mode").
- The update operation supports only one Commitment Business process in Input.
- Only the SOV sheets with "Fund Assignment" enabled (in the sheets) will be updated.
- In the SOV sheet, only the rows that have Cost code assigned to them are provided in input JASON.
- If a row is divided in breakdowns, both the "item#" and the "breakdown" values must be provided for identification for the row to be updated. For the SOV Auto-Order, if only one fund_code is provided in input, without fund_ratio, the default value of 100% will be applied to that fund_code.
- The SOV sheets that have been configured to be funded from the Commit Fund Sheet will not get updated from this update call.
Response Format
A JSON object is returned in the following format.
"data": [],
"message": [],
"status": <REST status code value>
A successful response displays a status code 200.
A failed response displays a message with a status code.
Response message contains key as "<record_no>/<item#>/<breakdown, if present>
And "item_status", "item_message" contains individual response for that row in SOV record.
Sample Response For SOV Auto-Ratio
"data":[
"message":[
"PO-0002/000010" :
"item_status":200,
"item_message":"success"
"PO-0002/000020.00001/BD1" :
"item_status":200,
"PO-0001/000010" :
"item_status":200,
"status":200
Sample Response For SOV Auto-Order
"data":[ ],
"message":[
{"uxfund20-0000/000010" :{
"item_status":200,
"status":200
Status codes are:
- 200, for success
- 3000, for Partial success.
