Configuring Oracle Integration for P6 System Activity Sheets in Shell Templates
Company Administrators and Shell Administrators can configure single shell templates of CBS type to use Oracle Integration as the default integration engine.
Benefits
- Streamlines configuration when new projects are created.
- Enforces organizational integration strategy (Oracle Integration-first or mixed).
Limitations
Updates affect new single shells only. Existing shells are unaffected.
Prerequisites
- Oracle Integration is enabled at the company level as the integration engine as outlined in the Initial Oracle Integration Setup.
- You have the required permissions to edit shell templates and set up P6 schedule integrations as an administrator.
- Existing Primavera Gateway integrations will be removed when switching to Oracle Integration. Be aware of business and technical impacts.
Procedure
To set up Oracle Integration as the default integration engine of choice in single shell templates of CBS shell type for P6 System Activity Sheets:
