Project/Shell Creation (Simple or Line Item)
The Resource BP form type is divided into the following forms:
  • Simple
  • Line Item
The Simple BP form type contains the following fields:
  • ID
  • Name
  • Description
  • Type
    Project/Shell Creation (selected by default and read-only)
  • Sub-Type
    • Simple (selected by default and read-only)
  • Classification
  • Level
    • Company
    • Project/Shell
  • Behavior
    • Workflow
    • Non-Workflow
  • Record Instances
    • Single
    • Multiple (selected by default and read-only)
The Line Item BP form type contains the following fields:
  • ID
  • Name
  • Description
  • Type
  • Sub-Type
    • Line Item (selected by default and read-only)
  • Classification
  • Projects or Shells only
  • Shell and sub shells
  • Level
    • Company
    • Project/Shell
  • Behavior
    • Workflow
    • Non-Workflow
  • Record Instances
    • Single
