System-Defined Data Elements for Activity Attribute Form
You can use the following system-defined data elements for the Activity Attribute Form:
Data Element Data Definition Element Label Purpose
uuu_activity_successor SYS Description Text 2000 Successor This element will display the successor activities for the selected activity
uuu_activity_early_start Date Only Picker Early Start This date data element will capture the early start date of the activity for float calculation
uuu_activity_early_finish Date Only Picker Early Finish This date data element will capture the early finish date of the activity for float calculation
uuu_activity_late_start Date Only Picker Late Start This date data element will capture the late start date of the activity for float calculation
uuu_activity_late_finish Date Only Picker Late Finish This date data element will capture the late finish date of the activity for float calculation
uuu_activity_constraint_type Activity Constraint Type (Data Set: As Soon As Possible) Activity Constraint Type This element will show the constraints available at activity level
For details, see the Unifier Data Reference Guide.
