Aconex Adapter Capabilities
The Aconex Adapter enables you to set up a connection with Aconex. It is one of many predefined adapters included with Oracle Integration. You can configure the Aconex Adapter as an invoke connection within an integration in Oracle Integration.
Adapter Capabilties
- Easy API Module Selection : Facilitates the seamless selection of various Aconex API modules, including:
- Directory
- Documents
- Project Fields
- Projects Tasks
- User Roles
- Workflows
- Simple Operation Selection: Allows effortless selection of specific operations (API service endpoints) within each selected API module. Each operation is accompanied by a basic description for usage clarification.
- Intuitive Data Mapping Functionality: Supports intuitive data mapping based on the selected operation, with mandatory fields highlighted as necessary.
- Automatic Population of Request Parameters: Automatically populates common request parameters essential for a successful API request, streamlining the integration process.
Adapter Benefits
- Accelerated Integration Timeline: Significantly reduces the time required to create integrations with Aconex through Oracle Integration.
- Simplified Integration Process: Enables seamless integration of Aconex with other applications, even without extensive knowledge of Oracle Integration or Aconex REST APIs. While familiarity with REST APIs can enhance certain functionalities, it is not mandatory for basic integration tasks.
- No Dependency on the Generic REST Adapter: Eliminates the need to rely on a generic REST adapter, providing a tailored solution for Aconex integration needs.
