3 Create an Oracle Aconex Cloud Adapter Connection
A connection is based on an adapter. You define connections to the specific cloud applications that you want to integrate.
Prerequisites for Creating a Connection
Every integration with Oracle Aconex APIs must be registered with Oracle, and you will receive the credentials required to uniquely identify the integration.
The first step is to decide which API Security method will be used, as the registration process differs depending on the chosen method.
The available methods are:
- Register an OAuth Integration
- Register a Basic Authentication Integration
For details about both methods, see Register a Customer integration in Aconex Support Central.
It is crucial to complete the registration process for the selected security method to establish a secure and successful connection between the adapter and Oracle Aconex.
OAuth Integration Registration: Necessary Steps
For OAuth-based integration, there are specific prerequisites and steps that need to be followed. One of the first steps is determining the type of OAuth integration that aligns with the requirements of the application.
The adapter uses the Non-Interactive Integration type for establishing connections - an integration that has no user interaction. This is a trusted client that uses JWT Bearer (otherwise known as User Assertion) grant type.For detailed instructions about implementing OAuth in a Non-Interactive Integration, see Implement OAuth in a Non-Interactive Integration.
For additional information, see Getting started with APIs in the Oracle Aconex REST API documentation.
Create a Connection
Before you can build an integration, you must create the connections to the applications with which you want to share data.
You can also create a connection in the integration canvas. See why working with projects is preferred.To create a connection in Oracle Integration:
- Decide where to start:
- Work in a project (see why working with projects is
preferred).
- In the navigation pane, click Projects.
- Select the project name.
- Click Integrations
- In the Connections section, click Add if no connections currently exist or + if connections already exist. The Create connection panel opens.
- Work outside a project.
- In the navigation pane, click Design, then Connections.
- Click Create. The Create connection panel opens.
preferred).
Select the adapter to use for this connection. To find the adapter, scroll through the list, or enter a partial or full name in the Search field.
Enter the information that describes this connection.
Element Description Name Enter a meaningful name to help others find your connection when they begin to create their own integrations.
Identifier Automatically displays the name in capital letters that you entered in the Name field. If you modify the identifier name, don't include blank spaces (for example,
SALES OPPORTUNITY).Role Select the role (direction) in which to use this connection.
Note: Only the roles supported by the adapter you selected are displayed for selection. Some adapters support all role combinations (trigger, invoke, or trigger and invoke). Other adapters support fewer role combinations.
When you select a role, only the connection properties and security policies appropriate to that role are displayed on the Connections page. If you select an adapter that supports both invoke and trigger, but select only one of those roles, you'll get an error when you try to drag the adapter into the section you didn't select.
For example, assume you configure a connection for the Oracle Service Cloud (RightNow) Adapter as only an invoke. Dragging the adapter to a trigger section in the integration produces an error.
Keywords Enter optional keywords (tags). You can search on the connection keywords on the Connections page.
Description Enter an optional description of the connection.
Share with other projects Note: This field only appears if you are creating a connection in a project.
Select to make this connection publicly available in other projects. Connection sharing eliminates the need to create and maintain separate connections in different projects.
When you configure an adapter connection in a different project, the Use a shared connection field is displayed at the top of the Connections page. If the connection you are configuring matches the same type and role as the publicly available connection, you can select that connection to reference (inherit) its resources.
Click Create.
Your connection is created. You're now ready to configure the connection properties, security policies, and (for some connections) access type.
- Follow the steps to configure a connection.
The connection property and connection security values are specific to each adapter. Your connection may also require configuration with an access type such as a private endpoint or an agent group.
- Test the connection.
