Activate the Integrations
You can activate the integrations all at once by activating the project, or you can activate each integration individually.
Preferred: Activate the Project (one click for all integrations)
Activating at the project level activates every selected integration (and version) in a single step.
  1. In the navigation pane, select Projects.
  2. Search for this accelerator:
    P6 to Unifier Resources and Schedule
  3. Hover over the project and click Activate "".
  4. In the Activate project panel, do the following:
    1. Select Project deployment.
    2. Select an appropriate Tracing level (Production, Audit, or Debug).
    3. Click the Activate button.
    A confirmation message appears.
    You can change the tracing level later by selecting Actions, and then Configure activation.
  5. Refresh the page to see the updated Activated status of the project.
Alternative: Activate Each Integration in the Project Individually
Repeat these steps for each integration in the accelerator.
  1. Go to the Integrations section of the project workspace.
  2. Activate the integration.
    1. Click Actions Actions icon next to the integration, then select Activate.
    2. In the Activate integration panel, select an appropriate Tracing level (Production, Audit, or Debug), then click the Activate button.
      A message confirms that the integration has been activated. Refresh the page to view the updated status of the integration.
