Configure the Primavera Unifier Connections
This accelerator uses the following connections to Primavera Unifier:
- Primavera Unifier API - Performs trigger and invoke operations to and from the Primavera Unifier REST API.
- Unifier basic - Invokes the Primavera Unifier token endpoint to identify whether the Primavera Unifier instance is single tenant or multi-tenant.
Both connections use the REST Adapter.
