Monitor the Integrations
You can monitor instances and errors directly within the project workspace and also from the global observability pages.
Monitor from the Project
  1. In the project workspace, click Observe.
  2. Click Instances to see all runs.
    You can filter by Status (for example, Succeeded or Errored) and Time window (time range).
    Click an instance to open the activity stream, which shows step-by-step execution and faults.
  3. Use the Errors panel to review failures and take action (resubmit or discard) where available.
Monitor from Global Observability
Use global observability for cross-project monitoring of health, performance, and errors.
  1. In the navigation pane, click Observability.
  2. Click Dashboards to review instance trends, error rates, and performance across projects.
