Oracle Primavera P6 EPPM Soap Connection
This connection uses the standard SOAP Adapter.
  1. In the Connections section, click Actions Actions icon on the connection, then select Edit.
  2. In the Properties section, do the following.
    1. In the WSDL URL field, enter the URL of the Primavera P6 EPPM Web Service WSDL.
      For example: https://<hostname>/p6ws/services/ImportService?wsdl
  3. In the Security section, do the following:
    1. In the Security policy field, select Username Password Token.
    2. In the Username and Password fields, enter the user name and password of the Primavera P6 EPPM integration user account.
  4. Click Test to ensure that your connection is successfully configured.
    A message confirms if your test is successful.
  5. Click Save. If prompted, click Save again.
  6. To return to the project workspace, click Go back Back icon.
