1 About This Recipe
Use this recipe to migrate Oracle Primavera Cloud project data along with all baselines from one workspace to another in the same environment or to another Oracle Primavera Cloud environment.
This recipe is available as Oracle Primavera Cloud — Oracle Integration | Migrate Project Data in Oracle Integration. Oracle provides this recipe as a sample only. The recipe is meant only for guidance, and is not warranted to be error-free. No support is provided for this recipe.
Overview
This recipe exports Oracle Primavera Cloud project data along with its baselines to a compressed file and imports them into another workspace within the same environment or to a workspace in another environment.
To use this recipe, you must install the recipe project and configure the delivered connections and resources in Oracle Integration. Then you update the property values to specify the integration parameters. You can activate and run the integration manually or specify an integration schedule. When triggered, the integration exports your project and baseline data into a compressed file and then imports the data into the target workspace.
System and Access Requirements
  • Oracle Integration Version 3
  • Oracle Primavera Cloud
  • An account in Oracle Primavera Cloud with view and edit privileges for a project and workspace
