Map Data to Synchronize a Project to a Target Workspace
Map the source project ID and workspace ID with the target project ID and workspace ID.
Map Source Project Code with Target Project Code
- In the Target section, expand , and then select Actions.
- Right-click Actions, and then select Create Target Node.
- In the Expression Builder, click Switch to Design
View
. - In the Design View window, enter Create.
- In the Source section, expand , and then select Project Code.
- In the Target section, expand , and then select Project Code.
- Drag the source element, Project Code, to the target element, Project Code.
- Continue to add mappings as needed between the source element, GetProjectDetails Response (Oracle Primavera Cloud), and the target element, SyncProjectRequest (Oracle Primavera Cloud).
- Click Validate.
- Click Go Back
, then click
Save.
