3 Add the Oracle Primavera P6 EPPM Adapter Connection to an Integration
When you select and place the Oracle Primavera P6 EPPM Adapter into the invoke area of an integration, the Adapter Endpoint Configuration Wizard is invoked. This wizard guides you through configuration of the P6 EPPM Adapter endpoint properties.
The following topics describe the wizard pages that guide you through configuration of the P6 EPPM Adapter as an invoke in an integration.
