Workflow to Create and Add a Connection to an Integration
You follow a very simple workflow to create a connection with an adapter and include the connection in an integration in Oracle Integration.
This table lists the workflow steps for both adapter tasks and overall integration tasks, and provides links to instructions for each step.
| Step | Description | More Information |
1 |
Access Oracle Integration. |
Go to
https://instance_URL/ic/home |
2 |
Create the adapter connections for the applications you want to integrate. The connections can be reused in multiple integrations and are typically created by the administrator. |
3 |
Create the integration. When you do this, you add trigger (source) and invoke (target) connections to the integration. |
Create Integrations in Using Integrations in Oracle Integration 3 and Add the Oracle Primavera P6 EPPM Adapter Connection to an Integration |
4 |
Map data between the trigger connection data structure and the invoke connection data structure. |
Map Data in Using Integrations in Oracle Integration 3 |
5 |
(Optional) Create lookups that map the different values used by those applications to identify the same type of object (such as gender codes or country codes). |
Manage Lookups in Using Integrations in Oracle Integration 3 |
6 |
Activate the integration. |
Activate an Integration in Using Integrations in Oracle Integration 3 |
7 |
Monitor the integration on the dashboard. |
Monitor Integrations During Runtime in Using Integrations in Oracle Integration 3 |
8 |
Track payload fields in messages during runtime. |
Assign Business Identifiers for Tracking Fields in Messages and Track Integration Instances in Using Integrations in Oracle Integration 3 |
9 |
Manage errors at the integration level, connection level, or specific integration instance level. |
Manage Errors in Using Integrations in Oracle Integration 3 |
