Primavera Unifier Adapter Capabilities
The Primavera Unifier Adapter enables you to set up a connection with Primavera Unifier. You can use this connection in integrations to connect with Unifier.
You can use the Unifier Adapter to fetch, create, or update a Business Process (BP) record (without attachments) in Unifier. It provides for an easy selection of the BP needed for integration. Based on the BP you select, the fields defined in the integration interface of that BP are available for mappings.
The Unifier Adapter provides trigger (inbound) and invoke (outbound) support. As a trigger, the adapter enables you to send the BP record data to Oracle Integration for further processing. As an invoke, the adapter enables you to create, update, and fetch records from and into Unifier.
The Unifier Adapter is one of many predefined adapters included with Oracle Integration. You can configure the Unifier Adapter as an invoke or trigger connection in an integration in Oracle Integration.
