4 Activate and Run the Accelerator
After configuring connections and resources, activate and run the accelerator through the Oracle Integration interface or REST API. Both methods require passing a JSON payload in the provided format.
To run the integration using the REST API, on the Configure and Run page, click the Endpoint Metadata tab. Copy the Endpoint URL and use additional information as necessary.Related Documentation
