General Configuration
Some configuration in Primavera Unifier and Oracle Identity Cloud Service is required before you can set up and use this recipe.
Create Integration Users
For each of the delivered connections in this recipe, you will need to create a dedicated integration user in Primavera Unifier. For details, see Creating Integration Users.
This recipe delivers two connections that connect to Primavera Unifier. One connection uses the Primavera Unifier Adapter, and the other connection uses the REST Adapter. To prevent 401 authorization errors from Primavera Unifier, each connection needs to use a separate integration user.
After you create the required integration users, this is how you will use them in this recipe:
In addition to these connections requiring a separate integration user, these integration users should not be used by other clients, such as Postman, etc. This is also to avoid 401 authorization errors from Primavera Unifier.
Get Relevant Permissions
Ensure that you have the relevant permissions in Primavera Unifier to configure Oracle Integration.
To set these permissions in Primavera Unifier:
  1. Go to the Company Workspace and switch to Admin mode.
  2. In the left Navigator, select User Administration, then select Access Control.
  3. In the right page, expand Administration Mode Access, expand Integrations, and then select Oracle Integration Cloud.
See Initial Oracle Integration Setup.
Add Primavera Unifier as a Trusted Application in Oracle Identity Cloud Service
Ensure that Primavera Unifier is added as a trusted application using the Client credentials grant type, in the Oracle Identity Cloud Service instance used with Oracle Integration.
This is typically done with the help of Oracle Support, as described in Initial Oracle Integration Setup in the Primavera Unifier documentation.
