Oracle Utilities Customer To Meter Fixes
The following table lists the product fixes included in this release:
Bug Number
Description
33461688
COPY OF 33381918 - AFTER DISABLING ODM IN C2M, ERROR ISSUED WHEN UPDATING PERSON CONTACT
33520008
COPY OF BUG 33422293 - AFTER DISABLING ODM IN C2M, MANUFACTURER MODEL UPDATE-ADD ERROR FOR NAVIGATION OPTION CODE
33583583
UPDATE X1-TEMPDVDET TO SKIP IF ODM IS NOT INSTALLED
33601750
COPY OF 31318328 - FIELD ACTIVITY PENDING ALERT IN C2M DASHBOARD ALERTS ZONE DOES NOT SHOW LIST OF PENDING FIELD ACTIVITIES
33638480
COPY OF BUG 33638469 - COPY OF BUG 33589695 - SP CHARACTERISTIC VALUE IS BLANK FOR SRCH_CHAR_VAL FIELD ON D1_SP_CHAR WHEN CREATED WITH PREMISE REPLICATOR
33657653
COPY OF BUG 33653640 - FIX COMPLETION ALGORITHM X1-CMPLCCBFA TO CHECK WHETHER CCB FA IS ALREADY COMPLETED
33666626
OUMDM-23768 MIGRATE PERSON
33700139
COPY OF 33647070 - DEVICE ONGOING SYNC REQUEST IS NOT SENDING POSITIVE ACKNOWLEDGMENT (C2M)
33741283
COPY OF 33724784 - DATACONNECT V1+ PREMISE FILE FOR OPOWER IS NOT PER SPEC (C2M)
33754440
OUMDM-23919 MIGRATE SERVICE AGREEMENT
33754595
OUMDM-23920 MIGRATE CONTRACT OPTIONS
33758906
COPY OF BUG 33758512 - UPDATE X1-TRSYRQFLD TO CONVERT MDM SP IDS TO ODM NODE IDS ONLY IF MOVEMENT ACTION IS BLANK
33779479
COPY OF 33859601 - COUNT MISMATCH IN AV VS OUAV IN USAGE EXCEPTIONS - FIX TO BUG 33659915
33780166
OUMDM-22820 MIGRATE METER READ - DELETE REWORK
33781796
CROSS INSTALLED PROCESS MENU IS NOT GROUPED CORRECTLY
33797571
REVIEW / ADJUST MENU LINE SEQUENCES (C2M)
33801780
REPLACE DEPRECATED APPLICATION SERVICE - DEFAULT EXECUTION APPLICATION SERVICE (F1-DFLTAPS) (C2M)
33826153
C2M - USAGE TRANSACTION IN MSCS WITH CUT-OFF DATE = DST CHANGE DATE GOES INTO ERROR
33831434
COPY OF BUG 33557444 - COPY OF BUG 33539138 - WHEN WE TRY TO UPLOAD LEGACY DATA TO CCB AND THEN SYNC TO MDM, WE'RE SEEING SYNC ERRORS WHEN RUNNING THE F1-SYNIL BATCH/CONVERSION INSERT BATCH
