Default Generic Application Services
By default, a whole set of Application Services are defined against base functions. In line with Data Ownership Rules some of these records can be altered and new functions added. A set of generic Application Services are also shipped with Oracle Utilities Customer To Meter to provide a mechanism for defining new zones, new objects or new menu items for rapid deployment.
There are two generic Application Services that can be used to secure objects, zones and menu items:
Application Service
Description
F1-DFLTAPS
This is a generic execution Application Service which is designed to secure zones and menu options. It only supports the Execute Access Method.
F1-DFLTS
This is a generic maintenance Application Service which is designed to secure business objects. It supports the Add, Modify, Delete and Inquire Access Methods.
Note: The use of these generic Application Services is optional.
