OAuth2 Support
Note: For customers using OAuth2 for Federated Security refer to the dedicated section in this guide for detailed instructions.
Oracle Utilities Customer To Meter supports OAuth2 for delegated access to API's within the product. From the configuration perspective the following is required for Oauth2:
The CLIENT-CERT setting should be specified for security in the product. This indicates that the security is coming from an external source to the domain.
Configure Oracle WebLogic domain security realm to support OAuth2 using the instructions provided with the relevant version of Oracle WebLogic.
If you are using a service provider like Oracle Identity Suite or Oracle Access Manager in association with Oracle WebLogic, then refer to the documentation provided with those products for domain specific setup instructions.
If you are using a third-party provider in association with Oracle WebLogic, refer to the documentation provided with that provider with additional setup instructions.
