How To Start Service When Multiple Service Points Measure Consumption
When you start service at a premise, the system automatically links service points to service agreements in the same manner as existed for the previous customer. So, if the previous customer amalgamated consumption of three service points and billed this under a single service agreement, the system will create the same configuration for the new customer.
This works fine when the unusual service point configurations have already been set up for the previous customer. However, it doesn't work when the premise is new. So, if you have a new premise that has multiple service points whose consumption needs to be amalgamated under a single service agreement, do the following:
• Start service for only one of the service points to be linked to the service agreement. When you start service, the system creates a service agreement, links the service point to it, and links a field activity to the service point.
• For every service point that wasn't linked to the service agreement:
▪ • After linking all the service points to the pending service agreement, manually activate the service agreement. This task is done on
Service Agreement – Main. While the service agreement might not be truly activated at this time, this step ensures necessary field activity requests are created behind the scenes.
That's it. The activation process will automatically activate the service agreement when the fieldwork is complete on all of its service points.
Parent topic
