Defining Bill Factors
You create a bill factor for every type of charge whose value is not specified directly in a calculation rule.
It is recommended to use two windows to set up a bill factor. On the first, you define general information describing how the bill factor is used in the system. On the second, you define all the characteristic values for the bill factor.
Parent topic
