Configurable Consumption Extracts
Configurable Consumption Extracts are measurement data extracts for a set of usage subscriptions optionally related to a specific market participant.
Configuration options for these extracts include:
• Type of Market Participant, based on Service Point Market Participant or Usage Subscription Market Participant tables and market relationship
• Usage Subscriptions Types associated with the market participant (typically a customer information system receiving bill determinants)
• Unique combinations of unit of measure (UOM), time of use (TOU), and service quantity identifier (SQI) associated with the usage subscriptions
• Specific identifiers used to identify the usage subscriptions, service points, and devices associated with extracted measurement data
• Date and time parameters and frequency of extract
• Extract file naming and compression options
Consumption extracts are exported to a file in a specified file location, either on an application server (in an on-premises implementation) or an Oracle Cloud Infrastructure Object Storage location.
Consumption extracts are created via Consumption Extract Requests. See Consumption Extract Requests in the Business User Guide.
This section describes the configuration needed for these types of consumption extracts.
Consumption Extract Types
Configuration for consumption extracts are defined via a Consumption Extract Type. See Consumption Extract Type in the Administrative User Guide for more information about creating these records.
Configurable consumption extract types should be created using the Extract US Consumption to File (D1-ExtractUSConsumptionToFile) business object. Refer to the embedded help on this business object for more details about the parameters defined for consumption extract types.
Extract US Consumption to File consumption extract types define the following parameters:
• The market participants for which measurement data will be extracted. You define market participants based on their type (Service Point Market Participant or Usage Subscription Market Participant) and market relationship type (retailer, distributor, supplier, and so on), and a specific market participant. Note: If Market Participant Specific is set to "No", the market participant used is based on the Usage Recipient on the Usage Subscription or its Usage Subscription Type.
• The consumption type (interval or scalar)
• One or more Usage Subscription Types and a related unique UOM/TOU/SQI combination
• The specific ID types to include in the extract file for the Usage Subscription, Service Point, child Service Point (if applicable), and Device
• Execution parameters, including:
◦ The date and time through which data has been extracted for this consumption extract type
◦ A Request Type. Request types used with consumption requests should be created using the Consumption Extract Request Type (D2-IntervalDataExtRepoType) business object, and should reference the Consumption Extract (D2-IntervalDataExtRepository) business object in the Request Business Object field. (see The Big Picture of Requests in the Application Framework Administrative User Guide)
◦ The frequency of extracts for this type (adhoc or daily)
◦ Batch controls used for the extract process (see Batch Controls below)
• File parameters, including:
◦ The file location where extract files will be saved (see External File Storage in the Application Framework Administrative User Guide)
◦ An optional child folder in the file location
◦ File naming options (including an optional prefix and date/time stamp)
◦ Whether or not to compress the extract file (file compression is performed using gzip)
Batch Controls
The data extract process and creation of export files is performed by the following batch controls:
• Extract Current US Intervals to File (D1-ECUSI): Used for daily extracts of interval consumption.
• Extract Replacement US Intervals to File (D1-ERUSI): Used for extracts of replacement historical interval consumption. This process runs against Change Data Capture records in the General Process table (see Initial Measurement Subsequent Correction Change Data Capture below).
• Extract Current US Scalar Reads to File (D1-ECUSS): Used for daily extracts of scalar consumption.
• Extract Replacement US Scalar Reads to File (D1-ERUSI): Used for extracts of replacement scalar interval consumption. This process runs against Change Data Capture records in the General Process table (see Initial Measurement Subsequent Correction Change Data Capture below).
These batch controls are run for a specific Consumption Extract Type and date range. Batch processing is threaded by on Usage Subscription ID.
Refer to Consumption Extract Requests - Batch Controls in the Defining DataConnect Options section of the Integrations chapter for general information about consumption extract batch processing,
The follow algorithms maintain measuring component date/times based on the latest measurement date time for the measuring component. These algorithms also check for a Consumption Extract Type that applies to the current initial measurement's measuring component and identifies whether the initial measurement is for a date/time that has already been extracted.
Algorithm
Description
Consumption Type
D1-UPD-DTMC
Update Latest Measurement Date/Time on MC with Consumption Sync
Interval
D1-UDTSCMCRE
Update Latest Measurement Date/Time on Scalar MC with Consumption Sync
Scalar
D1-UPD-DTMCF
Update Latest Date/Time on MC from a Future Measurement
Interval
D1-UPDDTSCMC
Update Latest Date/Time on Scalar Measuring Component
Scalar
If an initial measurement is for a date/time that has already been extracted, these algorithms create Change Data Capture records in the General Process table that capture the batch code, batch run number, and the initial measurement's ID. The "Replacement" batch processes run off of these records.
Note that the following parameter must be set to “true” on the above algorithms to enable historical change data capture:
• Capture CET Historical Measurement Changes: true
File Format - Interval
The interval extract process produces JavaScript Object Notation (JSON) files with the extract data described in the following table.
Note that interval extract files can store up to a maximum of 300 intervals. This means that export files can store approximately:
• 12.5 days worth of hourly data
• 3 days worth of 15 minute data
• 1 day worth of 5 minute data
Field
Sample Value
Comments
usId
995647003500
Usage Subscription ID defined by the Consumption Extract Type
usType
E-RES
Usage Subscription type
pSpId
458081
Parent Service Point ID, Null when there is no parent service point.
spId
458081_​001
Child Service Point ID
This is the Service Point ID defined by the Consumption Extract Type
dvcId
SN823287793219
Device ID defined by the Consumption Extract Type
uomTouSqi
KWH//
UOM / TOU / SQI, separated by forward slashes ("/")
tz
US/Eastern
Time zone of the service point.
This is the time zone name from the CI_​TIME_​ZONE table not the time zone code.
intPerDay
288
Number of Intervals for the day, will be 1 hour less or 1 hour more of intervals for DST transitions
intSize
300
Length of each interval in seconds
mktPart
DIRECT_​ENERGY
Market Participant ID of the market participant (if applicable)
stDttm
2020-01-01T00:00:00-05:00
Start of the day, similar to initial measurement, this represents the start of the first interval.
q1
1.325
Measurement Value for the first interval, the measurement date/time for this interval would be the stDttm plus the intSize
c1
301000
Measurement Condition for the first interval.
Null when "Regular" (501000)
q2
1.230
c2
301000
q/c 3 through 299 here
q300
.9134
c300
30100
Example:
{"usId":"995647003500", "usType":"E-RES", "pSpId":"458081", "spId":"458081_001", "dvcId":"SN823287793219", "uomTouSqi":"KWH//",
 "tz":"US/Eastern", "intPerDay":"288", "intSize":"300", "mktPart":"DIRECT_ENERGY",
 "stDttm":"2020-01-01T00:00:00-05:00", "q1":"1.325", "c1":"301000", "q2":"1.325",
 "c2":"301000" "q3":"1.325", "c3":"301000",
<intervening intervals>, "q300":"1.325", "c300":"301000"}
File Format - Scalar
The scalar extract process produces JavaScript Object Notation (JSON) files with the extract data described in the following table.
Name
Sample Value
Comments
c
301000
Measurement Condition for the scalar reading
dvcId
SN823287793219
enDttm
2020-01-02T00:00:00-05:00
End date/time of the reading
mktPart
DIRECT_​ENERGY
pSpId
458081
q
1.325
Measurement Value for scalar reading
r
678645
Dial reading of the meter
spId
458081_​001
stDttm
Start date/time of the reading (the End Date/Time of the previous reading)
tz
US/Eastern
uomTouSqi
KWH//
usId
995647003500
usType
E-RES
Usage subscription type
Example (3 records):
 "tz":"US/Eastern", "mktPart":"DIRECT_ENERGY", "stDttm":"2020-01-01T00:00:00-05:00",
 "enDttm":"2020-01-02T00:00:00-05:00", "q":"1.325", "c":"301000", "r":"678645"}
Extending Extract Processing
Some implementations may wish to extend and/or customize the extract process based on specific requirements.
Extending List of IDs To Use
Consumption Extract Types define specific types of IDs to use for Usage Subscriptions, Service Points, child Service Points (if applicable), and Devices. If an implementation wishes to extend the types of IDs available, they need to add appropriate values to the lookup flags used by each of ID type. The table below lists the lookup codes used by the "IDs to Use" fields.
ID Type
Lookup Flag
Usage Subscription Identifier Type (US_​ID_​TYPE_​FLG)
Service Point ID (used for both parent and child service points)
Service Point Identifier Type (SP_​ID_​TYPE_​FLG)
Device ID
Device Identifier Type (DVC_​ID_​TYPE_​FLG)
Processing Records and Creating Output Files
The extract process leverages the generic Plug-in Driven Background Processes functionality but works in a slightly different manner. Instead of using the Select Records algorithm to retrieve the IDs of the individual records to be processed, that algorithm returns a range of Usage Subscription IDs to be extracted and the Process Records algorithm performs the detailed query to extract the range of Usage Subscription IDs.
This provides two benefits:
1. There is no limitation on the length of the query in the Process Records algorithm.
2. Retrieving data for many Usage Subscriptions at a single time is significantly more efficient.
This means that any required customization can be achieved by creating a new custom (CM) batch control and duplicating the Process Records Groovy script. Changes can be made within the custom Groovy script to the extraction SQL to retrieve additional information or provide additional selection criteria. If any changes are needed to the file format that can be done within the record processing logic that populates the file.
The Process Records scripts include a number of steps each containing specific processing logic and SQL based on the configuration of the Market Participants on the Consumption Extract Type as well as whether or not the specified UOMs measure peak quantities or not. Be sure to edit each of these steps as appropriate when creating customized versions of these scripts.
