Windows 2022 Application Server
This section describes the software requirements for operating the application using the Windows application server.
Note: Windows Server is not supported for Production environments. Wherever Windows Server is referenced within this guide, it is supported for Test or Development environments only.
Supported Application Servers
Web/Application Server Tier
File and Directory Names Limitations
File and directory names cannot contain spaces. Due to the limitations in Windows, fully qualified filenames cannot exceed 2047 characters.
Oracle Database Client 19c - Runtime Option
Install the Oracle Client as described in the Oracle Client installation documentation. Use the cissys account to install the Oracle Client. If another user installs the Oracle Client, make sure the cissys user ID has the proper execute permissions.
For the cissys user ID, ensure that the environment variable ORACLE_CLIENT_HOME is set up, and that ORACLE_CLIENT_HOME/perl/bin is the first Perl listed in the cissys account's PATH variable.
Oracle Java Development Kit V17 or Later (64-Bit)
At the time of release, obtain the Oracle Java packages from:
https://www.oracle.com/java/technologies/downloads/The Oracle WebLogic Server requires the 64-bit version. The main prerequisite for the web server is the version of Java mentioned above.
For the userid cissys, ensure that the environment variable JAVA_HOME is setup, and that java_home/bin and java_home/lib can be found in cissys’ PATH variable.
Oracle WebLogic Server 14.1.2.x (64-bit)
Oracle WebLogic software can be downloaded from the Oracle website. This application server will run as a 64-bit application.
• Download and install 64-bit Java (as documented above) before installing WebLogic.
• Download and install WebLogic Server 14.1.2.x.
Note: Starting Oracle Utilities Application Framework V25.4, WebLogic native installation is required. Refer to the
Oracle WebLogic Configuration Guide for Oracle Utilities Application Framework (Doc ID 2413918.1) document on
My Oracle Support.
