Table_Name | Column_Name | Data Type | Data Length |
C1_CC_IDENTIFIER | CC_EXT_REF_ID | VARCHAR | 120 |
C1_CC_IDENTIFIER | CC_ID | CHAR | 10 |
C1_CC_IDENTIFIER | CC_ID_TYPE_FLG | CHAR | 4 |
C1_CC_IDENTIFIER | VERSION | NUMB | 5 |
C1_CC_LOG | ADHOC_CHAR_VAL | VARCHAR | 254 |
C1_CC_LOG | CC_ID | CHAR | 10 |
C1_CC_LOG | CC_INT_EVENT_DTTM | DTTM | 26 |
C1_CC_LOG | CC_INT_STAT_FLG | CHAR | 4 |
C1_CC_LOG | CC_INT_STAT_RSN_DESCR | VARCHAR | 500 |
C1_CC_LOG | CHAR_TYPE_CD | CHAR | 8 |
C1_CC_LOG | CHAR_VAL | CHAR | 16 |
C1_CC_LOG | CHAR_VAL_FK1 | VARCHAR | 50 |
C1_CC_LOG | CHAR_VAL_FK2 | VARCHAR | 50 |
C1_CC_LOG | CHAR_VAL_FK3 | VARCHAR | 50 |
C1_CC_LOG | CHAR_VAL_FK4 | VARCHAR | 50 |
C1_CC_LOG | CHAR_VAL_FK5 | VARCHAR | 50 |
C1_CC_LOG | DESCRLONG | VARCHAR | 4000 |
C1_CC_LOG | LOG_DTTM | DTTM | 26 |
C1_CC_LOG | LOG_ENTRY_TYPE_FLG | CHAR | 4 |
C1_CC_LOG | MESSAGE_CAT_NBR | NUMB | 5 |
C1_CC_LOG | MESSAGE_NBR | NUMB | 5 |
C1_CC_LOG | SEQNO | NUMB | 5 |
C1_CC_LOG | USER_ID | CHAR | 8 |
C1_CC_LOG | VERSION | NUMB | 5 |
C1_CC_LOG_PARM | CC_ID | CHAR | 10 |
C1_CC_LOG_PARM | MSG_PARM_TYP_FLG | CHAR | 4 |
C1_CC_LOG_PARM | MSG_PARM_VAL | VARCHAR | 2000 |
C1_CC_LOG_PARM | PARM_SEQ | NUMB | 3 |
C1_CC_LOG_PARM | SEQNO | NUMB | 5 |
C1_CC_LOG_PARM | VERSION | NUMB | 5 |
C1_NTF_EVT_CC_CL_TYPE | CC_CL_CD | CHAR | 4 |
C1_NTF_EVT_CC_CL_TYPE | CC_TYPE_CD | CHAR | 12 |
C1_NTF_EVT_CC_CL_TYPE | CC_TYPE_USG_FLG | CHAR | 4 |
C1_NTF_EVT_CC_CL_TYPE | NTF_EVT_TYPE_FLG | CHAR | 4 |
C1_NTF_EVT_CC_CL_TYPE | VERSION | NUMB | 5 |
C1_NTF_EVT_TYPE | BO_XML_DATA_AREA | XML | 1073741824 |
C1_NTF_EVT_TYPE | BUS_OBJ_CD | CHAR | 30 |
C1_NTF_EVT_TYPE | NTF_EVT_ACT_INACT_FLG | CHAR | 4 |
C1_NTF_EVT_TYPE | NTF_EVT_TYPE_FLG | CHAR | 4 |
C1_NTF_EVT_TYPE | NTF_MODE_FLG | CHAR | 4 |
C1_NTF_EVT_TYPE | NTF_TYPE_CD | VARCHAR | 30 |
C1_NTF_EVT_TYPE | VERSION | NUMB | 5 |
C1_NTF_EVT_TYPE_ALG | ALG_CD | CHAR | 12 |
C1_NTF_EVT_TYPE_ALG | NTF_EVT_ALG_ENTITY_FLG | CHAR | 4 |
C1_NTF_EVT_TYPE_ALG | NTF_EVT_TYPE_FLG | CHAR | 4 |
C1_NTF_EVT_TYPE_ALG | SEQ_NUM | NUMB | 3 |
C1_NTF_EVT_TYPE_ALG | VERSION | NUMB | 5 |
C1_NTF_EVT_TYPE_CHAR | ADHOC_CHAR_VAL | VARCHAR | 254 |
C1_NTF_EVT_TYPE_CHAR | CHAR_TYPE_CD | CHAR | 8 |
C1_NTF_EVT_TYPE_CHAR | CHAR_VAL | CHAR | 16 |
C1_NTF_EVT_TYPE_CHAR | CHAR_VAL_FK1 | VARCHAR | 50 |
C1_NTF_EVT_TYPE_CHAR | CHAR_VAL_FK2 | VARCHAR | 50 |
C1_NTF_EVT_TYPE_CHAR | CHAR_VAL_FK3 | VARCHAR | 50 |
C1_NTF_EVT_TYPE_CHAR | CHAR_VAL_FK4 | VARCHAR | 50 |
C1_NTF_EVT_TYPE_CHAR | CHAR_VAL_FK5 | VARCHAR | 50 |
C1_NTF_EVT_TYPE_CHAR | NTF_EVT_TYPE_FLG | CHAR | 4 |
C1_NTF_EVT_TYPE_CHAR | SEQ_NUM | NUMB | 3 |
C1_NTF_EVT_TYPE_CHAR | SRCH_CHAR_VAL | VARCHAR | 50 |
C1_NTF_EVT_TYPE_CHAR | VERSION | NUMB | 5 |
C1_QUESTION | BO_XML_DATA_AREA | XML | 1073741824 |
C1_QUESTION | BUS_OBJ_CD | CHAR | 30 |
C1_QUESTION | C1_QUESTION_CD | VARCHAR | 30 |
C1_QUESTION | C1_QUESTION_STATUS_FLG | CHAR | 4 |
C1_QUESTION | VERSION | NUMB | 5 |
C1_QUESTION_ANSWER | C1_ANSWER_CD | VARCHAR | 30 |
C1_QUESTION_ANSWER | C1_ANSWER_STATUS_FLG | CHAR | 4 |
C1_QUESTION_ANSWER | C1_ANSWER_STYLE_FLG | CHAR | 4 |
C1_QUESTION_ANSWER | C1_QUESTION_CD | VARCHAR | 30 |
C1_QUESTION_ANSWER | SEQ_NUM | NUMB | 3 |
C1_QUESTION_ANSWER | VERSION | NUMB | 5 |
C1_QUESTION_ANSWER_L | C1_ANSWER_CD | VARCHAR | 30 |
C1_QUESTION_ANSWER_L | C1_QUESTION_CD | VARCHAR | 30 |
C1_QUESTION_ANSWER_L | DESCR100 | VARCHAR | 100 |
C1_QUESTION_ANSWER_L | DESCRLONG | VARCHAR | 4000 |
C1_QUESTION_ANSWER_L | LANGUAGE_CD | CHAR | 3 |
C1_QUESTION_ANSWER_L | VERSION | NUMB | 5 |
C1_QUESTION_CHAR | ADHOC_CHAR_VAL | VARCHAR | 254 |
C1_QUESTION_CHAR | C1_QUESTION_CD | VARCHAR | 30 |
C1_QUESTION_CHAR | CHAR_TYPE_CD | CHAR | 8 |
C1_QUESTION_CHAR | CHAR_VAL | CHAR | 16 |
C1_QUESTION_CHAR | CHAR_VAL_FK1 | VARCHAR | 50 |
C1_QUESTION_CHAR | CHAR_VAL_FK2 | VARCHAR | 50 |
C1_QUESTION_CHAR | CHAR_VAL_FK3 | VARCHAR | 50 |
C1_QUESTION_CHAR | CHAR_VAL_FK4 | VARCHAR | 50 |
C1_QUESTION_CHAR | CHAR_VAL_FK5 | VARCHAR | 50 |
C1_QUESTION_CHAR | SEQ_NUM | NUMB | 3 |
C1_QUESTION_CHAR | SRCH_CHAR_VAL | VARCHAR | 50 |
C1_QUESTION_CHAR | VERSION | NUMB | 5 |
C1_QUESTION_L | C1_QUESTION_CD | VARCHAR | 30 |
C1_QUESTION_L | DESCR100 | VARCHAR | 100 |
C1_QUESTION_L | DESCRLONG | VARCHAR | 4000 |
C1_QUESTION_L | LANGUAGE_CD | CHAR | 3 |
C1_QUESTION_L | VERSION | NUMB | 5 |
C1_RESPONSE | BO_STATUS_CD | CHAR | 12 |
C1_RESPONSE | BO_STATUS_REASON_CD | VARCHAR | 30 |
C1_RESPONSE | BO_XML_DATA_AREA | XML | 1073741824 |
C1_RESPONSE | BUS_OBJ_CD | CHAR | 30 |
C1_RESPONSE | CRE_DTTM | DTTM | 26 |
C1_RESPONSE | CS_REQ_ID | CHAR | 14 |
C1_RESPONSE | F1_SVC_TASK_ID | CHAR | 14 |
C1_RESPONSE | ILM_ARCH_SW | CHAR | 1 |
C1_RESPONSE | ILM_DT | DATE | 10 |
C1_RESPONSE | RESPONSE_ID | CHAR | 14 |
C1_RESPONSE | STATUS_UPD_DTTM | DTTM | 26 |
C1_RESPONSE | VERSION | NUMB | 5 |
C1_RESPONSE_ANSWER | BO_XML_DATA_AREA | XML | 1073741824 |
C1_RESPONSE_ANSWER | C1_ANSWER_CD | VARCHAR | 30 |
C1_RESPONSE_ANSWER | C1_QUESTION_CD | VARCHAR | 30 |
C1_RESPONSE_ANSWER | C1_QUESTION_SUB_SEQ | NUMB | 3 |
C1_RESPONSE_ANSWER | C1_RESPONSE_ANSWER | VARCHAR | 4000 |
C1_RESPONSE_ANSWER | RESPONSE_ID | CHAR | 14 |
C1_RESPONSE_ANSWER | SEQ_NUM | NUMB | 3 |
C1_RESPONSE_ANSWER | VERSION | NUMB | 5 |
C1_RESPONSE_CHAR | ADHOC_CHAR_VAL | VARCHAR | 254 |
C1_RESPONSE_CHAR | CHAR_TYPE_CD | CHAR | 8 |
C1_RESPONSE_CHAR | CHAR_VAL | CHAR | 16 |
C1_RESPONSE_CHAR | CHAR_VAL_FK1 | VARCHAR | 50 |
C1_RESPONSE_CHAR | CHAR_VAL_FK2 | VARCHAR | 50 |
C1_RESPONSE_CHAR | CHAR_VAL_FK3 | VARCHAR | 50 |
C1_RESPONSE_CHAR | CHAR_VAL_FK4 | VARCHAR | 50 |
C1_RESPONSE_CHAR | CHAR_VAL_FK5 | VARCHAR | 50 |
C1_RESPONSE_CHAR | RESPONSE_ID | CHAR | 14 |
C1_RESPONSE_CHAR | SEQ_NUM | NUMB | 3 |
C1_RESPONSE_CHAR | SRCH_CHAR_VAL | VARCHAR | 50 |
C1_RESPONSE_CHAR | VERSION | NUMB | 5 |
C1_RESPONSE_K | ENV_ID | NUMB | 6 |
C1_RESPONSE_K | RESPONSE_ID | CHAR | 14 |
C1_RESPONSE_LOG | ADHOC_CHAR_VAL | VARCHAR | 254 |
C1_RESPONSE_LOG | BO_STATUS_CD | CHAR | 12 |
C1_RESPONSE_LOG | BO_STATUS_REASON_CD | VARCHAR | 30 |
C1_RESPONSE_LOG | CHAR_TYPE_CD | CHAR | 8 |
C1_RESPONSE_LOG | CHAR_VAL | CHAR | 16 |
C1_RESPONSE_LOG | CHAR_VAL_FK1 | VARCHAR | 50 |
C1_RESPONSE_LOG | CHAR_VAL_FK2 | VARCHAR | 50 |
C1_RESPONSE_LOG | CHAR_VAL_FK3 | VARCHAR | 50 |
C1_RESPONSE_LOG | CHAR_VAL_FK4 | VARCHAR | 50 |
C1_RESPONSE_LOG | CHAR_VAL_FK5 | VARCHAR | 50 |
C1_RESPONSE_LOG | DESCRLONG | VARCHAR | 4000 |
C1_RESPONSE_LOG | LOG_DTTM | DTTM | 26 |
C1_RESPONSE_LOG | LOG_ENTRY_TYPE_FLG | CHAR | 4 |
C1_RESPONSE_LOG | MESSAGE_CAT_NBR | NUMB | 5 |
C1_RESPONSE_LOG | MESSAGE_NBR | NUMB | 5 |
C1_RESPONSE_LOG | RESPONSE_ID | CHAR | 14 |
C1_RESPONSE_LOG | SEQNO | NUMB | 5 |
C1_RESPONSE_LOG | USER_ID | CHAR | 8 |
C1_RESPONSE_LOG | VERSION | NUMB | 5 |
C1_RESPONSE_LOG_PARM | MSG_PARM_TYP_FLG | CHAR | 4 |
C1_RESPONSE_LOG_PARM | MSG_PARM_VAL | VARCHAR | 2000 |
C1_RESPONSE_LOG_PARM | PARM_SEQ | NUMB | 3 |
C1_RESPONSE_LOG_PARM | RESPONSE_ID | CHAR | 14 |
C1_RESPONSE_LOG_PARM | SEQNO | NUMB | 5 |
C1_RESPONSE_LOG_PARM | VERSION | NUMB | 5 |
C1_SERVICE_CAT | BO_XML_DATA_AREA | XML | 1073741824 |
C1_SERVICE_CAT | BUS_OBJ_CD | CHAR | 30 |
C1_SERVICE_CAT | C1_SERVICE_CAT_CD | VARCHAR | 30 |
C1_SERVICE_CAT | VERSION | NUMB | 5 |
C1_SERVICE_CAT_CHAR | ADHOC_CHAR_VAL | VARCHAR | 254 |
C1_SERVICE_CAT_CHAR | C1_SERVICE_CAT_CD | VARCHAR | 30 |
C1_SERVICE_CAT_CHAR | CHAR_TYPE_CD | CHAR | 8 |
C1_SERVICE_CAT_CHAR | CHAR_VAL | CHAR | 16 |
C1_SERVICE_CAT_CHAR | CHAR_VAL_FK1 | VARCHAR | 50 |
C1_SERVICE_CAT_CHAR | CHAR_VAL_FK2 | VARCHAR | 50 |
C1_SERVICE_CAT_CHAR | CHAR_VAL_FK3 | VARCHAR | 50 |
C1_SERVICE_CAT_CHAR | CHAR_VAL_FK4 | VARCHAR | 50 |
C1_SERVICE_CAT_CHAR | CHAR_VAL_FK5 | VARCHAR | 50 |
C1_SERVICE_CAT_CHAR | SEQ_NUM | NUMB | 3 |
C1_SERVICE_CAT_CHAR | SRCH_CHAR_VAL | VARCHAR | 50 |
C1_SERVICE_CAT_CHAR | VERSION | NUMB | 5 |
C1_SERVICE_CAT_L | C1_SERVICE_CAT_CD | VARCHAR | 30 |
C1_SERVICE_CAT_L | DESCR100 | VARCHAR | 100 |
C1_SERVICE_CAT_L | DESCRLONG | VARCHAR | 4000 |
C1_SERVICE_CAT_L | LANGUAGE_CD | CHAR | 3 |
C1_SERVICE_CAT_L | VERSION | NUMB | 5 |
C1_SERVICE_CAT_SVC_CD | C1_SERVICE_CAT_CD | VARCHAR | 30 |
C1_SERVICE_CAT_SVC_CD | C1_SERVICE_CD | VARCHAR | 30 |
C1_SERVICE_CAT_SVC_CD | VERSION | NUMB | 5 |
C1_SERVICE_CODE | BO_XML_DATA_AREA | XML | 1073741824 |
C1_SERVICE_CODE | BUS_OBJ_CD | CHAR | 30 |
C1_SERVICE_CODE | C1_SERVICE_CD | VARCHAR | 30 |
C1_SERVICE_CODE | VERSION | NUMB | 5 |
C1_SERVICE_CODE_CHAR | ADHOC_CHAR_VAL | VARCHAR | 254 |
C1_SERVICE_CODE_CHAR | C1_SERVICE_CD | VARCHAR | 30 |
C1_SERVICE_CODE_CHAR | CHAR_TYPE_CD | CHAR | 8 |
C1_SERVICE_CODE_CHAR | CHAR_VAL | CHAR | 16 |
C1_SERVICE_CODE_CHAR | CHAR_VAL_FK1 | VARCHAR | 50 |
C1_SERVICE_CODE_CHAR | CHAR_VAL_FK2 | VARCHAR | 50 |
C1_SERVICE_CODE_CHAR | CHAR_VAL_FK3 | VARCHAR | 50 |
C1_SERVICE_CODE_CHAR | CHAR_VAL_FK4 | VARCHAR | 50 |
C1_SERVICE_CODE_CHAR | CHAR_VAL_FK5 | VARCHAR | 50 |
C1_SERVICE_CODE_CHAR | SEQ_NUM | NUMB | 3 |
C1_SERVICE_CODE_CHAR | SRCH_CHAR_VAL | VARCHAR | 50 |
C1_SERVICE_CODE_CHAR | VERSION | NUMB | 5 |
C1_SERVICE_CODE_L | C1_SERVICE_CD | VARCHAR | 30 |
C1_SERVICE_CODE_L | DESCR100 | VARCHAR | 100 |
C1_SERVICE_CODE_L | DESCRLONG | VARCHAR | 4000 |
C1_SERVICE_CODE_L | LANGUAGE_CD | CHAR | 3 |
C1_SERVICE_CODE_L | VERSION | NUMB | 5 |
C1_SERVICE_CODE_QUESTION | C1_BEHAVIOR_FLG | CHAR | 4 |
C1_SERVICE_CODE_QUESTION | C1_QUESTION_CD | VARCHAR | 30 |
C1_SERVICE_CODE_QUESTION | C1_SERVICE_CD | VARCHAR | 30 |
C1_SERVICE_CODE_QUESTION | SEQ_NUM | NUMB | 3 |
C1_SERVICE_CODE_QUESTION | VERSION | NUMB | 5 |
CI_CC | C1_SS_DELIVERY_TYPE | CHAR | 4 |
CI_CC | CC_INT_STAT_FLG | CHAR | 4 |
CI_CC | CC_INT_STAT_RSN_DESCR | VARCHAR | 500 |
CI_CC | CONTACT_VALUE | VARCHAR | 254 |
CI_CC | EDGE_APP_ID_FLG | CHAR | 4 |
CI_CC | MESSAGE_SUBJECT | VARCHAR | 256 |
CI_CC | NTF_CONTACT_ID | CHAR | 10 |
CI_CC | NTF_EVT_TYPE_FLG | CHAR | 4 |
CI_CC | NTF_INST_ID | CHAR | 32 |
CI_CC | NTF_PREF_ID | CHAR | 14 |
CI_CC | NTF_TYPE_CD | VARCHAR | 30 |
C1_BI_FT_VW | XFER_TO_GL_DT | Date | 10 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | MAINT_OBJ_CD | CHAR | 12 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE1 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE2 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE3 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE4 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE5 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | QSTN_REL_OBJ_SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | QSTN_REL_OBJ_TYPE_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | QUESTION_APPL_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | VERSION | NUMB | 5 |
C1_CS_REQ_TYPE_QUESTION | BO_XML_DATA_AREA | XML | 1073741824 |
C1_CS_REQ_TYPE_QUESTION | BUS_OBJ_CD | CHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | C1_ANSWER_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | C1_QUESTION_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | CS_REQ_TYPE_QSTN_STAT_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QUESTION | CUST_CL_CD | CHAR | 8 |
C1_CS_REQ_TYPE_QUESTION | PERS_BUS_QSTN_APPL_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QUESTION | QUESTION_APPL_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QUESTION | QUESTION_PLACE_GRP | VARCHAR | 254 |
C1_CS_REQ_TYPE_QUESTION | SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QUESTION | SORT_SEQ5 | NUMB | 5 |
C1_CS_REQ_TYPE_QUESTION | VERSION | NUMB | 5 |
C1_CS_REQ_TYPE_QUESTION_REL | C1_ANSWER_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION_REL | C1_QUESTION_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION_REL | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION_REL | REL_QSTN_SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QUESTION_REL | SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QUESTION_REL | VERSION | NUMB | 5 |
C1_QUESTION_ANSWER | CHAR_TYPE_CD | CHAR | 8 |
C1_CS_REQ_TYPE_REL_UPD | BO_XML_DATA_AREA | XML | 1073741824 |
C1_CS_REQ_TYPE_REL_UPD | BUS_OBJ_CD | CHAR | 30 |
C1_CS_REQ_TYPE_REL_UPD | CHAR_TYPE_CD | CHAR | 8 |
C1_CS_REQ_TYPE_REL_UPD | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_REL_UPD | CS_REQ_TYPE_REL_UPD | VARCHAR | 254 |
C1_CS_REQ_TYPE_REL_UPD | CS_REQ_TYPE_REL_UPD_SEQ | NUMBER | 3 |
C1_CS_REQ_TYPE_REL_UPD | FLD_NAME | CHAR | 30 |
C1_CS_REQ_TYPE_REL_UPD | REL_UPD_PROC_ALG_CD | CHAR | 12 |
C1_CS_REQ_TYPE_REL_UPD | SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_REL_UPD | TBL_NAME | CHAR | 30 |
C1_CS_REQ_TYPE_REL_UPD | UPD_ELEM_XPATH | CHAR | 254 |
C1_CS_REQ_TYPE_REL_UPD | UPD_ENT_BUS_OBJ_CD | CHAR | 30 |
C1_CS_REQ_TYPE_REL_UPD | VERSION | NUMBER | 5 |
C1_CS_REQ_TYPE_SVC_CRIT | BO_XML_DATA_AREA | XML | 1073741824 |
C1_CS_REQ_TYPE_SVC_CRIT | BUS_OBJ_CD | CHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT | C1_ANSWER_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT | C1_QUESTION_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT | CRITERIA_BASIS_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_SVC_CRIT | CRITERIA_COMPARISON_VALUE | VARCHAR | 254 |
C1_CS_REQ_TYPE_SVC_CRIT | CRITERIA_OPERATOR_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_SVC_CRIT | CSRT_SEC_FALSE_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_SVC_CRIT | CSRT_SEC_INSUFFICIENT_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_SVC_CRIT | CSRT_SEC_TRUE_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_SVC_CRIT | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT | ELIGIBILITY_CRITERIA_SEQ | NUMBER | 3 |
C1_CS_REQ_TYPE_SVC_CRIT | START_SA_OVRD_SW | CHAR | 1 |
C1_CS_REQ_TYPE_SVC_CRIT | STOP_SA_OVRD_SW | CHAR | 1 |
C1_CS_REQ_TYPE_SVC_CRIT | VERSION | NUMBER | 5 |
C1_CS_REQ_TYPE_SVC_CRIT_ALG | ALG_CD | CHAR | 12 |
C1_CS_REQ_TYPE_SVC_CRIT_ALG | ALG_ENTITY_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_SVC_CRIT_ALG | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT_ALG | ELIGIBILITY_CRITERIA_SEQ | NUMBER | 3 |
C1_CS_REQ_TYPE_SVC_CRIT_ALG | SEQ_NUM | NUMBER | 3 |
C1_CS_REQ_TYPE_SVC_CRIT_ALG | VERSION | NUMBER | 5 |
C1_CS_REQ_TYPE_SVC_CRIT_L | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT_L | DESCR100 | VARCHAR | 100 |
C1_CS_REQ_TYPE_SVC_CRIT_L | DESCRLONG | VARCHAR | 4000 |
C1_CS_REQ_TYPE_SVC_CRIT_L | ELIGIBILITY_CRITERIA_SEQ | NUMBER | 3 |
C1_CS_REQ_TYPE_SVC_CRIT_L | LANGUAGE_CD | CHAR | 3 |
C1_CS_REQ_TYPE_SVC_CRIT_L | VERSION | NUMBER | 5 |
C1_CS_REQ_TYPE_SVC_CRIT_SATY | CIS_DIVISION | CHAR | 5 |
C1_CS_REQ_TYPE_SVC_CRIT_SATY | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT_SATY | DEFAULT_SW | CHAR | 1 |
C1_CS_REQ_TYPE_SVC_CRIT_SATY | ELIGIBILITY_CRITERIA_SEQ | NUMBER | 3 |
C1_CS_REQ_TYPE_SVC_CRIT_SATY | SA_TYPE_CD | CHAR | 8 |
C1_CS_REQ_TYPE_SVC_CRIT_SATY | VERSION | NUMBER | 5 |
C1_CS_REQ_TYPE_SVC_CRIT_STOP | CIS_DIVISION | CHAR | 5 |
C1_CS_REQ_TYPE_SVC_CRIT_STOP | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_SVC_CRIT_STOP | DEFAULT_SW | CHAR | 1 |
C1_CS_REQ_TYPE_SVC_CRIT_STOP | ELIGIBILITY_CRITERIA_SEQ | NUMBER | 3 |
C1_CS_REQ_TYPE_SVC_CRIT_STOP | SA_TYPE_CD | CHAR | 8 |
C1_CS_REQ_TYPE_SVC_CRIT_STOP | START_OPT_CD | CHAR | 12 |
C1_CS_REQ_TYPE_SVC_CRIT_STOP | VERSION | NUMBER | 5 |
C1_QUESTION | C1_ANSWER_STYLE_FLG | CHAR | 4 |
C1_QUESTION | CHAR_TYPE_CD | CHAR | 8 |
C1_CS_REQ_TYPE_QUESTION | DFLT_ANSWER | VARCHAR | 254 |
