New Tables
Table
Name
Description
F1_REDACTION_RULE
Redaction Rule
Used to define redaction configuration for fields that may contain personal identifiable information.*
F1_REDACTION_RULE_L
Redaction Rule Language
Language table related to the Redaction Rule table.*
CI_MD_FLD_ADDTL
Field Additional Attributes
This is an extension of the CI_MD_FLD table and is used to capture additional information about a field.
F1_MO_UPD_BACKUP
Entity Key Backup Table
This table is part of generalized export batch it is used to keep a backup of all entity keys exported by a specific batch run number
F1_MIGR_OBJ_DATA
Migration Object Data
This is a child table to store Migration Object Content that is currently stored directly on the migration object itself
F1_BATCH_RUN_ANALYTICS_SNAP*
Batch Run Analytics Snapshot
Reserved for future use.
F1_BATCH_THD_ANALYTICS_SNAP*
Batch Thread Analytics Snapshot
*Future use only.
