Table | Name | Description |
W1_AST_DERMS_EVTCTL_CSTHIST* | Asset DERMS Event Control History | Used to store the control score history for an asset. |
W1_DESIGN_ELEMENT_CHKLST_TYP | Design Element Checklist Type | Used to store General and Permit Required Checklist Types against the Design Element to be created when a Template Construction Work Order creates a Construction Activity. |
W1_DESIGN_ELEMENT_DEP | Design Element Dependency | Used to store Construction Activity Dependencies against the Design Element to be created when a Template Construction Work Order creates a Construction Activity. The Dependencies would need to be within the Template Construction Activities of the same Template Construction Work Order. |
W1_CU_CU_USAGE | Compatible Unit CU Usage | Used to store configuration data related to compatible units usage |
W1_TMPL_WO_DOCUMENT | Template Work Order Document | Child table of Template Work Order table, used to store documents related to template work orders. |
W1_WO_DOCUMENT | Work Order Document | Child table of Work Order table, used to store documents related to work orders. |
