Sample SQL for Enabling ILM in C2M for CC&B (Initial Install)
This section provides more detail about steps needed to fully support ILM on tables for maintenance objects that support the functionality. Two maintenance objects are shown:
• To Do Entry, which does not include a LOB field.
• Sync Request, which does include a LOB field.
Other maintenance object's implementations can follow the appropriate pattern based on whether there is a LOB field or not.
The following DDL(s):
• Follow Naming convention recommendations for partitions\subpartitions\tablespaces.
• Ensure all the ILM Storage requirements are incorporated, failing which, ILM functionality will not be achieved.
• Partitions are defined with respective Tablespace.
• Child Tables are referenced partitioned.
• Ensure all compression recommendations are incorporated.
