Bug Number | Description |
Oracle Utilities Customer Care and Billing | |
33162122 | COPY OF 31637758 - WHEN DUPLICATING A USER, USER'S CIS DIVISIONS ARE NOT COPIED |
34357540 | COPY OF 34190379 - SA TYPE SA RELATIONSHIP TYPE SCREEN HAS SOME ISSUES |
34444350 | GDE ADDITIONAL FIXES - MO AUDIT ALGO NOT BEING TRIGGERED FOR SOME PROGRAM |
34588681 | COPY OF 34076633 - AFTER PATCH 33400634, ISSUE 2 PERSISTS: ERROR WHEN GENERATING A BILL: ¿SA (<SA ID>) DOES NOT CONTAIN ANY BILLABLE SUBSA |
34693614 | COPY OF 34638755 - ISSUES STILL PERSISTS AFTER INSTALLING PATCH 34555722 |
34717470 | COPY OF 34354754 - PROCESS FLOW: A. ID NUMBERS ARE NOT SAVED |
34735941 | COPY OF 34119432 - TENDER TYPE LIMIT WHEN POSTING NON-CIS PAYMENT |
34765826 | COPY OF 34154590 - SYSTEM ERROR ENCOUNTERED ADDING PREDEFINED CHARACTERISTIC |
34769770 | COPY OF 34675755 - BCS: CMA FOR C1-ACCOUNT MISSING SA FROM PAYOR ACCOUNT |
34781557 | COPY OF 34187675 - PAYMENT ARRANGEMENT REQUEST ERROR |
34781805 | COPY OF 34661924 - STOP AND TRANSFER PROCESS FLOW: PERSON IDENTIFIER ID NUMBER DISPLAY AND FORMAT ISSUES |
34790025 | COPY OF 34724108 - NON-BILLED BUDGET MONITORING FIELD IS MISSING ON THE SA TYPE PAGE |
34812762 | COPY OF 34708656 - N60 CCS CREATING 4 TENDER CONTROLS WITH SAME TENDER SOURCE AFTER RUNNING BALAPY BATCH |
34821984 | COPY OF 34674949 - PREPAY BILL SEGMENTS GRAPH NOT SHOWING CORRECTLY |
34822100 | COPY OF 34813306 - REDWOOD: BIGFIX: 22A: THE DESCRIPTION IS STILL DISPLAYED EVEN THOUGH THE VALUE IN THE TEXTBOX IS ALREADY BLANK/REMOVED |
34823297 | COPY OF 34817943 - REDWOOD: BIGFIX: 22A: (CCB) POSITION OF END DATE IS OFF ON OUTAGE CALL QUERY PAGE |
34823870 | COPY OF 34801684 - SP_SRC_STATUS_FLG NOW REQUIRED ON DOING START ON CCB/MDM INTEGRATION |
34831263 | COPY OF 34820598 - BCS - PERFORMANCE FOR CMA (FW-MIGRATION) - SERVICE PROVIDER CHANGES |
34843489 | COPY OF 33165397 - PDT - CHANGE PERSON LINKED TO ACCOUNT, ERROR IN START/STOP |
34852087 | COPY OF 32232830 - PERSON ONLY CUSTOMER CONTACTS NOT BEING CREATED |
34852095 | COPY OF 34599458 - START SERVICE PROCESS FLOW NOT LOADING THE SA DETAILS |
34855784 | COPY OF 34855709 - XMLINDEX NOT SUPPORTED IN ADB (23A) |
34865082 | COPY OF 34859246 - UNABLE TO REMOVE SYNC REQUEST MONITOR AS MONITOR PROCESS ON C1-PARENTEXTERNALREPOPLUSSYNC |
34892887 | COPY OF 34804721 - TABLE IS BLANK ON USAGE AND BILLING ZONE IN CUSTOMER360 PORTAL. |
34893488 | COPY OF 34759120 - STOP SERVICE PROCESS FLOW â ERROR ENCOUNTERED WHEN PERSON HAS MORE THAN 10 CHARACTERISTICS CONTINUED |
34893504 | COPY OF 34719534 - REGISTRATION POINT CHARACTERISTICS GETS DELETED WHEN ENCOUNTERING ERROR ON SAVE |
34893509 | COPY OF 34372722 - ISSUES IN ADD OTHER PERSON FUNCTIONALITY IN START SERVICE PROCESS FLOW |
34899240 | REVERT MULTI-CIS DIVISION CHANGES FOR DSS INVITE GUEST FUNCTIONALITY |
34930854 | COPY OF 34779808 - PROD: SYSTEM ERROR WHEN BILLING A BILLABLE CHARGE SA WITH A RATE AFTER 21C UPGRADE |
34965522 | COPY OF 34796855 - BILL SEGMENT SUBTOTAL SUMMARY CALC LINE AMOUNT ON 2ND BSEG HEADER IS INCORRECT |
34989189 | COPY OF 34805241 - MORE THAN ONE ACCOUNT FOUND FOR THE PREMISE |
34993797 | COPY OF 34985138 - ADD VALUES TO C1-SQDTTMHIGHLIGHTTYPELOOKUP EXTENDABLE LOOKUP |
35009771 | COPY OF 34935252 - MATH CALC RULE NOT WORKING WITH INTERVAL BILL FACTOR AND INTERVAL SERVICE QUANTITY |
35019377 | COPY OF BUG 35018423 - CMA - PLEASE INCLUDE SA RELATIONSHIP IN C1-ACCOUNT MIGRATION PLAN |
35020760 | COPY OF 35017685 - REDWOOD: BIGFIX: 22A: (CCB) DOUBLE VERTICAL SCROLLBAR |
Oracle Utilities Meter Data Management | |
25114375 | READER REMARK ADD DISPLAYS 3 EDITABLE FIELDS THAT CANNOT BE CHANGED |
31613891 | SCRIPT D1-PROCESSBF DOES NOT POPULATE SPID WHEN PKVALUE1 IS POPULATED |
33956123 | COPY OF 33956118 - COPY OF 33956112 - COPY OF 33182151 - NEGATIVE ESTIMATION INT |
33956146 | COPY OF 33956089 - COPY OF 33926207 - REQUESTED COPY FOR 2.4 OF BUG 33825380 - N |
34026220 | COPY OF BUG 34026207 - COPY OF BUG 34026196 - CONNECT DEVICE COMPLETION EVENT DOES NOT HANDLE "DEVICE STATUS LEFT" FROM INBOUND COMMUNICATION |
34080256 | COPY OF 34080250 - NO READ OUTAGE IMDS CREATED WHEN THEY ARE NOT SUPPOSED TO. |
34174848 | COPY OF 34174844 - COPY OF 34174836 - COPY OF 34137391 - SP-EQUIPMENT COUNT IS N |
34294534 | FULL REFRESH OF THE CONTEXT UPON NAVIGATING TO THE PREMISE |
34370652 | COPY OF BUG 34370646 - INTERVAL ADJ FROM SCALAR VEE RULE SHOULD CHECK CONDITION RANGE FIRST BEFORE DOING SCALAR PCT CHECK |
34445531 | COPY OF 34445524 - DATA QUALITY ASSESSMENT AND IS ESTIMATE FLAG INCORRECTLY MARKED |
34468080 | COPY OF BUG 34468076 - COPY OF BUG 34414511 - USAGE TRANSACTION CORRECTION PROCESSOR ACTIVITY IS NOT BEING CREATED |
34497155 | COPY OF 34497149 - COPY OF 34497144 - COPY OF 34303577 - PERIODIC ESTIMATION CREATING INCORRECT INTERVAL ESTIMATIONS DURING OUTAGE |
34532630 | COPY OF 34532609 - COPY OF 34187461 - FOR CHANNEL STATISTICS, THE START AND STOP OF THE STATISTICS MSRMT IS NOT CALCULATED AS DESCRIBED |
34544292 | COPY OF BUG 34544279 - INSERTION OF NEW CHAR ROW EVEN WHEN THERE IS NO CHANGE TO THE CHAR ITSELF |
34555386 | COPY OF BUG 34555382 - USAGE PERIOD END DATE IS NOT UPDATING TO MATCH END READ #2 |
34657173 | COPY OF 34657105 - VEE ESTIMATION INTERVAL PROXY DAY RULE NOT WORKING IN C2M |
34717058 | COPY OF 34717051 - IMD EXCEPTION - ESTIMATED MEASUREMENT WITH MISSING USAGE SUBSCRIPTION EXCEPTION |
34742269 | COPY OF BUG 34742265 - CONSUMPTION SYNC ACTIVITY ROLLS BACK TO PENDING RATHER THAN ISSUE-DETD FOR FAILED ESTIMATION |
34745006 | COPY OF BUG 34744998 - COPY OF BUG 34744995 - COPY OF BUG 34056248 - SYSTEM ERROR APPEARS ON CLICKING 'VERIFY DATES' ON THE IMD |
34760626 | COPY OF 34760622 COPY OF 34675282 - SENSUS IMD FORMAT INCORRECT FOR SPRING DST DAYLIGHT SAVINGS TIME |
34760637 | COPY OF 34760633 - SENSUS IMD FORMAT INCORRECT FOR SPRING DST DAYLIGHT SAVINGS TIME (NATIVE) |
34765140 | COPY OF 34765135 - COPY OF 34765133 - COPY OF 34765131 - COPY OF 34726857 - UNABLE TO SEARCH USAGE TRANSACTION ID THROUGH USAGE EXTERNAL ID FROM BASE PORTAL ON PROD |
34767077 | COPY OF 34767073 - DAILY SCALAR USAGE RULE RETURNS MEASUREMENTS AFTER DEVICE REMOVAL DATE/TIME |
34768638 | COPY OF 34753095 - COPY OF 34753087 - COPY OF 34747437 - MV90 LOADING - INDEX OUT OF RANGE |
34769619 | COPY OF BUG 34247813 - BACK-TO-BACK FAILING TO START SERVICE AFTER CUSTOMER CUT FOR NON-PAYMENT |
34777625 | COPY OF 34777618 - COPY OF 32768400 - CLOSING BSEG NOT PICKING UP USAGE ON NEW METER FOR METER EXCHANGES. CAUSING LOST REVENUE FOR CLIENT |
34783790 | COPY OF BUG 34783758 - MDM - ODM CHANGES: [OIC] DELIVER OUTBOUND MESSAGE TYPES |
34783804 | COPY OF BUG 34783766 - [DACS] SUBSCRIPTION ATTRIBUTES/ATTRIBUTE VALUES ARE NOT RENDERING PROPERLY |
34784235 | COPY OF 34784234 - COPY OF 34784231 - COPY OF 34783588 - EXTRACT ADDITIONAL INFORMATION INTO DATACONNECT INTERVAL AMI EXTRACT FOR BHE & EL PASO |
34787318 | COPY OF 34787294 - COPY OF 34787259 - COPY OF 34787193 - COPY OF 34748019 - MV90 BATCH IS NOT PROCESSING COMPLETE FILE |
34788270 | COPY OF 34788262 - COPY OF 34734462 - ARRAY MATH SHOULD LOOK TO MC SET NOT DATA SOURCE MC SET |
34789925 | COPY OF 34789919 - COPY OF 34239575 - PERIODIC ESTIMATION BATCH D1-SMMTR FOR SMARTMETER BATCH IS STUCK AND NOT PROCESSING RECORD ON RERUN. |
34795447 | METER INSIGHTS MASTER CONFIGURATION SHOULD HAVE THE OPTION TO ENTER LAST MEASUREMENT THRESHOLD |
34800416 | COPY OF BUG 34800386 - COPY OF BUG 34160375 - NEW LOCATION SHOULD NOT BE THE SAME AS THE CURRENT LOCATION PROCESS ERROR IN WAM |
34802941 | COPY OF 34341619 - 2.8 - ROUTE MANAGEMENT ZONE ISSUES |
34803200 | REDWOOD: SOM ACTIVITY TYPE PORTAL ZONE HEIGHTS ARE SO SMALL |
34810001 | COPY OF 34809996 - COPY OF 34677661 - INSTALL EVENT OUTBOUND SYNC REQUEST RECORD NOT BEING CREATED. |
34812657 | COPY OF 34812653 - COPY OF 34812650 - COPY OF 34812645 - COPY OF 34517280 - D1-SP-URCF THAT EVALUATES SP ELEMENTS IS NOT CONSIDERING THE EFFECTIVITY DATE OF SP CHARACTERISTIC |
34814315 | COPY OF BUG 34490041 - COPY OF BUG 33966182 - REMOTE DISCONNECT ACTIVITY ISSUE |
34815923 | COPY OF 34815782 - COPY OF 34815216 - COPY OF 34668872 - METER OPERATIONAL DASHBOARD - UNABLE TO FILTER SELECT/DESELECT BY EXCEPTION TYPE |
34816637 | COPY OF 34816636 - COPY OF 34641105 - MULTI TIME ZONE SUPPORT DOES NOT SEEM TO BE WORKING CORRECTLY (MDM) |
34819333 | COPY OF BUG 34819324 - COPY OF BUG 33876988 - DEVICE TYPE DROPDOWN ON SERVICE POINT EQUIPMENT QUERY POP UP DOES NOT DISPLAY ELIGIBLE SP DEVICES |
34821956 | COPY OF BUG 34821954 - COPY OF BUG 34622732 - NO ERROR OR POP-UP MESSAGE WHEN THE LOADING IMD VIA CSV FAILS |
34825500 | COPY OF 34825491 - COPY OF 34610278 - SCALAR AGGREGATION HAS INEFFICIENT QUERY |
34847704 | COPY OF BUG 34847697 - N60 AFTER TRANSFER ON ROUTE MANAGEMENT, ACCOUNT'S BILL CYCLE NOT UPDATED TO BE IN SYNC WITH CHANGED SP MEASUREMENT CYCLE |
34848691 | COPY OF 34626715 - FA INBOUND SCHEMA CHANGED TO USE LOOKUP THAT DOESN'T CONTAIN VALUES SENT FROM MWM |
34856629 | COPY OF 34885297 - REDWOOD - START/END DATE/TIME FIELDS ARE DISPLAYING EXTRA TEXT |
34858480 | COPY OF 34858479 - COPY OF 34858470 - COPY OF 34839485 - MULTIPLE ELEMENTS WITH SAME NAME FOR MASTER CONFIG BO D2-USAGETRANEXPORTCONFIG |
34858855 | COPY OF 34858839 - COPY OF 34858808 - COPY OF 34822043 - REDWOOD: BIGFIX: 22A: (MDM) MISSING HORIZONTAL SCROLLBAR ON MULTIPLE PAGES |
34859145 | COPY OF 34859135 - COPY OF 34859129 - COPY OF 34768153 - REDWOOD - (MDM) IN ACTIVITY FOR PAYLOAD STATISTIC, PRESS <ENTER> WON'T EXPAND SECTION - RECORD INFORMATION |
34872509 | COPY OF BUG 34872501 - COPY OF BUG 34872494 - COPY OF 34827610 - INCORRECT VALUE APPLIED TO LONG INTERVAL ALARM IN MSCS |
34874399 | COPY OF 34874395 - ERROR OBJECT SECTION IS MISSING IN THE SYNC RESPONSE AFTER UPGRADE |
34880029 | COPY OF 34773272 - COPY OF 34762319 - COPY OF 34709848 - COPY OF 34533564 - VEE EXCEPTION RAISED - ZERO CONSUMPTION VEE RULES SHOULD NOT TRIGGERED ON ENERGIZED METERS |
34880299 | COPY OF 34490492 - COPY OF 34490476 - COPY OF 34355878 - COPY OF 34333201 - COPY OF 34320670 - D1-MQTDS IS NOW LONGER TIMING-OUT BUT IS UNABLE TO PROCESS MC |
34882841 | COPY OF BUG 34686683 - DELETE EDIT USER DIVISION GENERATES "ONE DIVISION FOR A USER MUST BE SET AS PRIMARY" ERROR |
34884741 | COPY OF 34884740 - COPY OF 34830801 - MV90 PULSE MULTIPLIER NOT BEING APPLIED DURING IMPORT |
34900541 | CLOUD-ONPREMISE: FILE NOT PROCESS AND GENERATES ERROR WHEN PROCESSING FROM OUAF. |
34900909 | ILM: ADD PARALLELISM TO F1_ILMAD (BATCH CONTROL AND JAVA) |
34902019 | COPY OF BUG 34902017 - COPY OF BUG 34902016 - COPY OF BUG 34888346 - ACTIVITY TYPE LABEL NOT PRESENT IN ACTIVITY MAINTENANCE UI PAGE |
34908176 | COPY OF BUG 34945675 - MDM USAGE SUBSCRIPTION SEARCH BY ADDRESS ZONE RETURNS INCORRECT RESULTS |
34910360 | COPY OF BUG 34733709 - COPY OF BUG 34733707 - COPY OF BUG 34676818 - IMDS W/ READER REMARKS (NO READ) UPDATE MOST RECENT MSRMT DATE/TIME EVENT WITHOUT MSRMT |
34917649 | COPY OF 34917645 - CUT FOR NON PAYMENT ORCHESTRATOR ISSUING WRONG ACTIVITY |
34919516 | COPY OF BUG 34919513 - COPY OF BUG 34919511 - COPY OF BUG 34892314 - MEASUREMENT PORTAL - MEASUREMENT INFO STRING - DISPLAYS INCORRECT VALUE AND PRECISION |
34921829 | COPY OF 34789454 - OSB FOR MV90 IS NOT PROCESSING COMPLETE FILE |
34922333 | TM POLLING SSN: APPLICATION DEFAULTED REQUEST SELECTION FOR MEASUREMENT DESTINATION CAUSING THE COMMAND TO COMPLETE AUTOMATICALLY |
34929410 | COPY OF BUG 34527570 - MSCS 21C BUG 34112835 - DEVICE QUERY SEARCH BY ADDRESS DOES NOT RETURN HEAD END SYSTEM DATA |
34930236 | COPY OF BUG 34512201 - SERVICE POINTS WITH SP TYPE CATEGORY METER OR ITEM DO NOT ALLOW THE DISPLAY OF MULTI-ITEM INFORMATION SECTION. |
34948964 | COPY OF 34948960 - COPY OF 34948959 - COPY OF 34883088 - NAVIGATING FROM INSTALLED ITEMS/EQUIPMENT TO SP IS NOT POSSIBLE IN CCS |
34952080 | COPY OF 34952064 - COPY OF 34952036 - COPY OF 34825326 - ON DEMAND READ IWS RESPONSE DOESN'T HAVE USEABLE MSMTS BECAUSE THEIR MC ISN'T IDENTIFIED |
34956455 | COPY OF 34956451 - ACTIVITY RETRIES ARE NOT WORKING AS PER THE ACTIVITY TYPE CONFIGURATION |
34965682 | COPY OF 34947642 - SSN POLLING ENH: D7-ADDMETERREADJOBSCALARDRP BO POLLING ERROR STATE ERROR ON D1-WTTMOUT ALGO |
34971757 | ODMMDM INTEGRATION - D1-ODM-TMOT ALGORITHM TRANSITIONS AUTOMATICALLY TO SYNCHRONIZED |
34990093 | COPY OF BUG 34990091 - COPY OF BUG 34990088 - COPY OF BUG 34949879 - IMD BATCH DON'T FINALIZE IMDS AND STILL PENDING |
34993444 | COPY OF BUG 34971200 - UNABLE TO STOP SA IN 22A |
34996276 | COPY OF 34996267 - COPY OF 34960791 - DG ADAPTER - UNABLE TO CONVERT ELEMENT '/D1-INITIALLOADIMD/PREVEE/STDT' VALUE '2022-06-01-00.00.00' FROM XSD TO OUAF INTERNAL FORMAT |
35000494 | COPY OF 34890468 - 2.8 FA COMPLETION EVENT: UPDATE DEVICE LOCATION - NEW DEVICE DATA DETAILS - BADGE NUMBER NOT UPDATED |
35009084 | COPY OF ENH 34958345 - UNAVAILABILITY OF USAGE OF TOU MAPS IN COINCIDENT PEAK AND INDIVIDUAL SP DEMAND. |
35012879 | COPY OF BUG 35001133 - DEVICE CHARS AND DEVICE TYPE VALID CHARS ARE NOT RENDERING PROPERLY |
35019688 | COPY OF BUG 35019687 - COPY OF BUG 35019678 - COPY OF BUG 35019674 - COPY OF BUG 35006539 - WEATHER DATA NOT FINALIZING TO MSCS |
35022045 | COPY OF BUG 35022037 - INITIAL MEASUREMENT DATA HISTORY: DATES ARE NOT IN SEQUENCE ACCORDING TO END DATE TIME |
35029606 | COPY OF 35029595 - COPY OF 35029594 - COPY OF 35028265 - DATACONNECT INTERVAL AMI EXTRACT CREATES MULTIPLE HEADERS |
35033091 | CHANGE THE LABEL TO SUBSCRIPTION IN ATTRIBUTE VALUES MAINTENANCE ZONE |
35033097 | COPY OF BUG 35054190 - CHARACTERISTICS TYPES ARE NOT FILTERED BY ENTITY IN THE DROPDOWN |
35034599 | COPY OF BUG 35034595 - COPY OF BUG 34948568 - 360 DEGREE VIEW - MEASUREMENT DATA GRAPH NOT VISIBLE |
35047984 | COPY OF 35032836 - CMA BATCH F1-MGTAP - ERRORING AFTER 22C PATCH |
35048066 | OUMDM-30352 MIGRATION PLAN - DEVICE TYPE SERVICE QUANTITY |
35048869 | IMD FAILS TO MOVE FROM PENDING WITH NPE |
35048960 | COPY OF 35048959 - COPY OF 35048958 - COPY OF 35022335 - REFERENCING BUG 34905019 SUB-USAGE TRANSACTION #2 NOT RECOGNIZING START TIME FROM PARENT UT |
35055229 | COPY OF BUG 35055215 - COPY OF BUG 35055177 - COPY OF BUG 34381762 - ISSUE WITH BILL PRINT BLEX PATCH |
35059074 | UGBUPD-12695 MSCS TOOLS: REMOVE UNWANTED IMDS - BOS |
35074951 | COPY OF BUG 35074950 - COPY OF BUG 35065190 - COPY OF BUG 34700448 - CSV UPLOAD PAGE ERRORS FOR STANDALONE MEASURING COMPONENT |
35083546 | COPY OF 35073238 - IMDS WENT INTO VEE EXCEPTION AFTER MV90 UPLOAD, <MCM> NODE IS MISSING AFTER PATCH CCS 22C MP3.1.0 |
35093726 | UGBUPD-12695 - BATCH CONTROL - REMOVE NON-FINAL IMDS |
Oracle Utilities Customer to Meter | |
34332748 | CRISP - MIGRATE ADMIN - JAVA FIELD NAME OF READOUT TYPE LOOKUP VALUES IS NOT CAMEL CASE |
34332770 | FOR EACH CHAR TYPE HAVING METER/ITEM AS ENTITY DEVICE MUST BE ADDED TO ENTITY LIST |
34332803 | CRISP - MIGRATE ITEM AND MIGRATE SP BATCH EXECUTION WITH X1DE MODE DELETING ALL THE MDM/ODM RECORDS |
34561252 | CROSS INSTALLED METER: OVERRIDE NAVIGATION OPTION FROM SUMMARY PROCESS FLOW PANEL |
34657530 | OUT OF SERVICE LOCATION ON DATA MIGRATION MASTER CONFIG GETS DELETED EACH TIME ADMIN MIGRATION IS EXECUTED |
34720465 | COPY OF 34637813 - 2.8 - ERROR "ASSET TYPE NOT FOUND" WHILE TRYING TO RETIRE THE ASSETS |
34736927 | DESIGN CHANGE: PREVENT MASTER DATA PK ON SERVICE TASK TYPE ADMIN |
34748244 | COPY OF 34748237 - COPY OF 34637736 - X1-MIGAD X1-MIGSA DIVISION FIELD IS NOT POPULATED ON THE CONVERTED USAGE SUBSCRIPTION |
34748624 | CONTORLLABLE DEVICE - HEAD END DEFAULTING HAPPENS ON UPDATE ACTION ON DEVICE PAGE. |
34751929 | [DACS] REMAINING FOLLOW-UP ITEMS ON DEVICE LOCATION AND CONTROLLABLE DEVICE |
34754939 | PROGRAM ID SHOULD BE INCLUDED IN "X1-PROGRAMELIGIBILITYANDQUALIFICATION" IWS RESPONSE |
34761645 | DESIGN CHANGE: REMOVE BADGE NUMBER VALIDATION UPON SERVICE TASK VALIDATION |
34761914 | UNENROLLMENT NOT SENDING SYNC REQUEST OUTBOUND MESSAGE TO OIC |
34762168 | ERROR WHILE CREATING ENROLL SERVICE TASK WITHOUT MONITOR IN PENDING STATE |
34766558 | COPY OF BUG 34766111 - MIGSM ERROR: ASSETNODE_CHANDLER_ASSET MUST EITHER BE INSTALLED/ASSOCIATED TO A LOCATION OR ATTACHED |
34766636 | X1-DASPE BATCH MOVES TO ERROR WHEN MORE THAN ONE ACTIVE NON ELIGIBLE CHILD SUBSCRIPTIONS EXIST ON PARENT |
34767043 | BUG TO TRACK "INITIATIVE - DIGITAL ASSET INITIATIVE" STORY ISSUES |
34767177 | CHANGE "USAGE SUBSCRIPTION" LABEL TO "PROGRAM SUBSCRIPTION" IN DACS - NMS DIGITAL ASSET CUSTOMER SYNC REQUEST SCREEN |
34767826 | ISSUES RELATED TO BRING YOUR OWN - CUSTOMER OWNED ASSETS |
34767905 | DESIGN CHANGE: DO NOT REPLACE FIELD ACTIVITY WITH A NEW ONE FOR X1AC DEVICE SETUP ACTION |
34777172 | COPY OF 34777168 - COPY OF 34718305 - X1-MIGP NULLPOINTEREXCEPTION - CANNOT HANDLE SCENARIO PERSON HAS NO ACCOUNT, MULTIPLE ISSUES |
34780035 | DESIGN CHANGE: PROGRAM SUBSCRIPTION AND DEVICE LOCATIONS ARE ACTIVE WHEN SERVICE TASK IS VALIDATED |
34799764 | COPY OF 34786645 - UNABLE TO UPDATE/ADD UNIT OF MEASURE(UOM) IF MEASURES PEAK QUANTITY FIELD IS SET TO YES/NO FROM UI |
34818506 | ON DELETING ASSET - ERROR IS THROWN IN FULL CONTEXT ZONE |
34818853 | COPY OF BUG 34737336 - X1-MIGSM ERROR - PLUGINDRIVENGENERICTHREADITERATIONWORKER - LIST HAS 2 REFERENCES WITH THE SAME KEYS |
34825854 | COPY OF 34812432 - CROSS INSTALLED METER: OCBG NOT SHOW UP DURING THE SWAP WHEN THE METER INSTALLATION MAY START LATER |
34828627 | COPY OF BUG 34828619 - CAN'T CANCEL INITIATING ACTIVITY F1 VALUE IS MISSING AND TRANSITION FROM TO STATUS…FAILED |
34836500 | PROGRAM SUBSCRIPTION - CHANGE EXTERNAL ID LABEL |
34850159 | COPY OF 34849480 - ADD NEW FIELD IN OCBG LIST FOR BILL SEGMENT SEQUENCE. |
34850324 | UNENROLLMENT STILL SENDING ACTIVE DEVICE STATUS |
34850454 | COPY OF BUG 34850442 - DELETE BO X1-EVENTPARTICAPATIONERROR |
34871488 | COPY OF 34768708 - INCORRECT RECORD RETRIEVED BY FK_REFERENCE CHARACTERISTIC |
34875498 | COPY OF 34875493 - COPY OF 34835369 - X1-MIGP POPULATES INCORRECT CREATE DATE TIME VALUE FOR PERSONS HAVING MULTIPLE MAIN ACCOUNTS. |
34895782 | POPULATE DETAILS TO THE SERVICE TASK AFTER DERIVING THE METERED SERVICE |
34899792 | DEVICE SCORES SHOULD NOT BE WITHIN THE QUOTES IN FILE GENERATED ON BATCH JOB RUN X1-SDCSE IN DACS |
34916697 | DEVICE WHICH ARE "INACTIVE" IN DACS, X1-SDCSE BATCH JOB SHOULD NOT PICK THE SCORES IN FILE |
34930349 | COPY OF 34498632 - INVALID ERROR WHILE UPDATING TOU MAP TEMPLATE |
34934298 | COPY OF BUG 34401902 - SQL QUERY NOT RETURNING ALL BILL CYCLE SCHEDULES |
34934333 | COPY OF BUG 34522046 - ITEM TYPE CALCULATION RULE DOES NOT WORK FOR METERED SERVICE POINTS. |
34954282 | COPY OF 34954274 - COPY OF 34954271 - COPY OF 34905019 - USAGE REQUEST INTERVAL PROCESSING PERIOD NOT RECOGNIZED IN SUB USAGE TRANSACTION |
34988982 | COPY OF 34917993 - CMA - C1-MDM2PERSONSYNCREQUEST CREATING D1-CONTACT WHEN PERSON IS CREATED DOES NOT CONSISTENTLY WORK |
34996871 | COPY OF 34978074 - UNABLE TO ADD/DELETE SP CHARACTERISTIC |
35016377 | [DACS] POST EVENT: [REFACTOR] MOVE EVENT EXT ID TO POST OUTCOME LIST |
35038379 | DACS - ADD DIVISION (DIGITAL ASSET MANAGEMENT) GENERATES AN ERROR |
35040368 | COPY OF 35028430 - VPD FOR MIGRATION PLAN INSTRUCTION MUST CHECK FOR CLIENT IDENTIFIER |
35061184 | COPY OF BUG 35061169 - X1-MIGSM BATCH IS NOT UPDATING THE ASSET STATUS AS 'IN STORE' FOR THE REMOVED IE RECORDS. |
35061530 | COPY OF 34855104 - UNABLE TO LAND ON SP PAGE FROM PREMISE CONTEXT MENU |
35062532 | DESIGN CHANGE - METERED SP TO BE STAMPED ON THE DEVICE LOCATION DURING DIGITAL ASSET ENROLLMENT |
35064531 | COPY OF BUG 35064527 - COPY OF BUG 35064518 - COPY OF BUG 35063458 - ISSUE WAS FOUND ON A BILL SEGMENT WITH A SINGLE UT |
35068985 | CTM-11400 PROGRAM SUBSCRIPTION CALCULATION GROUP - FALLBACK CALC GROUP |
35081981 | CTM-11378 DEFAULT PROGRAM SUBSCRIPTION MAIN CUSTOMER AND EXTERNAL ACCOUNT ID FROM METERED SERVICE |
35085141 | COPY OF 35085140 - COPY OF 34958869 - X1-MIGSA - EXTERNAL ACCOUNT ID NOT CORRECT IN D1_US_IDENTIFIER IF US_ID_TYPE_FLG IS D2EA |
35094704 | COPY OF 34788994 - PRE-EVENT CANCEL REASON NOT SHOWING CORRECTLY IN THE EVENT PARTICIPATION LOG |
