Before You Upgrade
Review the list of operating system, application server, and database server combinations supported for this version of Oracle Utilities Customer to Meter in the Supported Platforms section in Supported Platforms and Hardware Requirements.
For further assistance, contact My Oracle Support before you upgrade.
Note: While upgrading a previously installed application server, it is recommended to take a backup before starting the upgrade procedure. The upgrade installation removes the existing environment including the configurations.
Copying and Decompressing Install Media for the Oracle Utilities Customer to Meter Database and Application Components
Refer to the Copying and Decompressing Install Media section in Installing the Application Server Component of Oracle Utilities Application Framework for instructions on copying and decompressing install media.
Setting Permissions for the cistab file in UNIX for the Oracle Utilities Customer to Meter Application Component
