Application Framework Prerequisite Patches
Oracle Utilities Application Framework patches must be installed prior to installing Oracle Utilities Customer to Meter. The patches listed below are available as a convenience rollup, C2M-V2.9.0.2.0-FW-PREREQ-MultiPlatform.zip, included in the downloaded media pack.
Refer to the instructions included in the rollup directory for steps to install the patches.
Bug Number
Description
38091236
Copy - To Do Entries can be Worked On even if the user has no 'Change' access for the To Do Entry application service
38207227
Upgrade 4.5.0.2.0 with ojdbc17 jar for 23ai
38313860
Copy - Support navigation across rows in "edit in place" grids using arrow keys
38368219
Copy - Pages not loading properly when there are references to purged To Do entries
38368223
Copy - Overdue monitoring batchs are not being activated in system
38368227
Copy - To Do Summary dashboard / sidebar zone is unnecessarily counting Open To Do entries, causing slowness
38368236
Copy - Error when viewing data via a CM extension that has been archived by ILM and where the record is a composite key
38368244
Copy - Fields not populated by scripts executed during application launch
38405514
Upgrade of Commons-Beanutils Library
38410890
Upgrade of JSON-SMART Library
38412025
Upgrade of DOMPurify Library
38421525
Upgrade of commons-fileupload library
38433154
Upgrade of Nimbus-jose-jwt Library
38434582
Copy - Some log tab displays an error after a To Do Purge job completion
38492603
Environment with Java 17 and Weblogic 14 fails when an IWS with an empty Transaction Type mapping is submitted
38518718
Upgrade of Velocity-engine-core and Commons-lang Library
38546006
Copy - Blank Screen shown after Payment Arrangement Process Flow cancellation
38558538
Copy - IWS Deployment Issues with JDBC version 23.9 libraries
38569861
FW 4.5.0.2.0 - Upgrade Hibernate in OUAF from v4 to v5
