Operating Systems and Application Servers
This section details the operating system and application server combinations on which this version of Oracle Utilities Customer to Meter is supported.
Application Server Operating Systems
• Oracle Linux 8.x or 9.x (64-bit) for x86_64
• Windows 11 Version x and Windows Server 2022 (for OUAF SDK use only)
Prerequisite Application Server Software
• Oracle Database Client 19c
• Oracle Database Client 23.x (Linux platform only)
• Oracle Java SE Development Kit 17.0.x (Windows and Linux platforms only)
• Select jars from Hibernate ORM 4.1.0
Notes:
Oracle Linux is 100% user space-compatible with Red Hat Enterprise Linux, therefore, Oracle Utilities Application Framework is also supported on Red Hat Enterprise Linux.
Refer to the Oracle Utilities Application Framework Database Administrator’s Guide for information on Oracle database server requirements.
Refer to the Certification Matrix for Oracle Utilities Products (Document ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products have been added.
Please note the following:
• Version numbers marked with a “+” are the MINIMUM version supported. That version and all future 4th digit updates will be supported.
Example: Oracle 19c means that 19 and any higher versions of Oracle 19 are supported.
• An “x” indicates that any version of the digit designed by the “x” is supported.
Example: Linux 8.x indicates that any version of Linux 8 (8.0, 8.1, 8.2 etc) will be supported.
Windows Server
• Windows Server is not supported for Production environments. Wherever Windows Server is referenced within this guide, it is supported for Test or Development environments only.
WebLogic Server
• Oracle WebLogic Server (Fusion Middleware Infrastructure) 14.1.2
• Customers must download Oracle WebLogic Server from the Oracle Software Delivery Cloud.
Oracle Database Server
Prerequisite database server software (on any vendor supported platform where x is vendor supported version):
• Oracle Database Server 19c Enterprise Edition
• Oracle Database Server 23ai
• Oracle Database Server 19c Standard Edition
Notes:
• Oracle Database Enterprise Edition and the Partitioning and Advanced Compression options are not mandatory but are recommended. Standard Edition should only be considered suitable for very small, pilot projects or development environments where scalability, performance, and database size-on-disk are not important considerations. Oracle Database Enterprise Edition, including the Advanced Compression and Partitioning options, is strongly recommended in all other situations.
• The following patch is mandatory to enable support for Oracle Database 23ai Enterprise Edition 23.x:
Bug 38207227 - Upgrade 4.5.0.2.0 with ojdbc17 jar for 23ai
Oracle VM Support
This version of Oracle Utilities Customer to Meter is supported on Oracle VM Server for x86 for supported releases of Oracle Linux and Microsoft Windows operating systems.
Refer to My Oracle Support knowledge base article 249212.1 for Oracle’s support policy on VMWare.
SDK - Supported Combinations
Refer to the SDK documentation for supported platforms and installation instructions.
