Oracle Linux 8.x/9.x and Red Hat Linux 8.x/9.x Application Server
This section describes the software requirements for operating the application using the Oracle Linux or Red Hat Linux application server.
Supported Application Servers
Web/Application Server Tier
Oracle Enterprise Linux 8.x/9.x or Red Hat Enterprise Linux 8.x/9.x Operating System Running on x86_64 64-bit Architecture
UNIX Administrator UserID
The following user groups and accounts have to be created to install and administer the application:
Note: It is recommended that you change the default values for security reasons.
Throughout this document the administrator user ID is often referred to as the “cissys” user ID. You should substitute that with the customer defined user ID when not using the default value. After the initial install, the software should always be managed using that user ID.
By default, “cissys” is the only user ID that can be used to access the installed files.
1. Create the “cisusr” user group.
2. Create the “cissys” user. The primary group is “cisusr”.
3. Set the primary shell for cissys user to Korn Shell.
The shell scripts use “>” to overwrite shell functionality. By default, your operating system may be configured to not allow this functionality in the Users shell.
To avoid file access permission problems while executing scripts, consider placing the following command into cissys profile script:
set +o noclobber
Security Configuration
Various options exist to secure a system. In this application all files will be created with the minimum permissions required to ensure that group-readable, group-writable and group-executable files will have the correct user groups and to restrict the permissions available to legitimate users. In this way, a low privileged end user cannot directly edit configuration files and thereby bypass application security controls.
The following users and group categories must be defined to implement this security. For demonstration purposes the following users and groups will be used. These users must be created according to industry standards (including password policies). All users should be created with a default umask of 077 to ensure files created during normal operation have the correct permissions.
Replace these users and groups for your installation defaults:
Note: The Oracle Client and WebLogic should be installed as the user who will stop and start the application. For example, if you plan to run the application as the install user these components must belong to cissys.
You must use the same user for starting and stopping a process. For example, if cissys is used to start the application server, the use cissys to stop it as well.
Oracle Client 19c - Runtime Option
Install the Oracle Client as described in the Oracle Client installation documentation. Use the cissys account to install the Oracle Client. If another user installs the Oracle Client, make sure the cissys user ID has the proper execute permissions.
For the cissys user ID, ensure that the environment variable ORACLE_CLIENT_HOME is set up, and that ORACLE_CLIENT_HOME/perl/bin is the first Perl listed in the cissys account’s PATH variable.
Oracle Java Development Kit V17 or Later (64-bit)
At the time of release, obtain the Oracle Java packages from:
https://www.oracle.com/java/technologies/downloads/The Oracle WebLogic Server requires the 64-bit version. The main prerequisite for the web server is the version of Java mentioned above.
For the userid cissys, ensure that the environment variable JAVA_HOME is setup, and that java_home/bin and java_home/lib can be found in cissys’ PATH variable.
Hibernate 4.1.0
You must install Hibernate 4.1.0 before installing Oracle Utilities Customer to Meter. For instructions to install Hibernate 4.1.0, refer to the
Installing Hibernate 4.1.0 section.
