Bug/Patch Number | Description |
38569861 | FW 4.5.0.2.0 - Upgrade Hibernate in OUAF from v4 to v5 |
38091236 | To Do Entries can be Worked On even if the user has no 'Change' access for the To Do Entry application service |
38207227 | Upgrade 4.5.0.2.0 with ojdbc17 jar for 23ai |
38258435 | In zone maintenance - display, html in the column config is applied. It should show the raw value of config. |
38313860 | Support navigation across rows in "edit in place" grids using arrow keys |
38368219 | Pages not loading properly when there are references to purged To Do entries |
38368223 | Overdue monitoring batchs are not being activated in system |
38368227 | To Do Summary dashboard / sidebar zone is unnecessarily counting Open To Do entries, causing slowness |
38368229 | Europe/Dublin time zone not reflected in local time |
38368236 | Error when viewing data via a CM extension that has been archived by ILM and where the record is a composite key |
38368244 | Fields not populated by scripts executed during application launch |
38405514 | Upgrade of Commons-Beanutils Library |
38410890 | Upgrade of JSON-SMART Library |
38412025 | Upgrade of DOMPurify Library |
38421525 | Upgrade of commons-fileupload library |
38433154 | Upgrade of Nimbus-jose-jwt Library |
38434582 | Some log tab displays an error after a To Do Purge job completion |
38492603 | Environment with Java 17 and Weblogic 14 fails when an IWS with an empty Transaction Type mapping is submitted |
38518718 | Upgrade of Velocity-engine-core and Commons-lang Library |
38524160 | OCTOBER 2025 CPU ROLLUP BUG |
38546006 | Blank Screen shown after Payment Arrangement Process Flow cancellation |
38558538 | IWS Deployment Issues with JDBC version 23.9 libraries |
38632964 | submitBatchRest.sh for comma parameter value |
38651863 | Algorithm Parameter validation not working consistently |
38658801 | Security Issue |
38729167 | Upgrade of Bouncy Castle Library |
38830584 | Remove Meta Data Lookup Changes Made for DUMMY FOR CCB 2.9.0.2.0HOT PATCH PROCESSING |
38767932 | ILLEGAL ARGUMENT EXCEPTION ON HIBERNATE EVENT DEFAULT EVICT EVENT LISTENER ONEVICT |
38724363 | "List has 2 references with the same keys" error encountered in Panel 2 of Stop Process Flow |
38722502 | Performance issue in Customer 360 - Payment Agreement due to multiple Field Description service calls |
38712863 | Case Log does not wrap |
38696858 | Customer Contact Reminders does not wrap |
38658925 | WXViewAccountList retrieves an error when trying to filter results |
38655855 | Error duplicating a user linked to CIS Division |
38653094 | C1CAGYXPR SCRIPT RAISES AN ERROR FOR FINANCIALLY RESPONSIBLE PERSON FOR ACCOUNT WITHOUT MAILING ADDRESS |
38620352 | ALGORITHM TYPE C1-APR-TMOUT - NEW TO DO CREATED BUT TO DO CREATION THRESHOLD IS NOT REACHED YET |
38616402 | C1-SSStartStopXferServiceTask BO Waiting For Additional Actions to transition to Discard |
38611378 | Unable to create/update Billable charge using services C1BillableChargeAdd |
38604060 | Performance issue in Customer Identification panel of the SST Start Service process flow when person has large number of accounts. |
38522779 | SCHEDULED PAYMENTS LOG ZONE IS NOT DISPLAYING IN CONTROL CENTRAL-ACCOUNT INFORMATION PAGE |
38518747 | PDT - CCB - Date Of Birth showing incorrect format for existing Person in Start Service Process Flow |
38503096 | MISSING TO DO CHARS FOR TO DO ENTRIES CREATED BY C1-TAPCN BATCH |
38496917 | Web User Summary zone resizing issue, dropdown getting hidden |
38496875 | Concurrency Error During C1-ADCRL (ILM Crawler - Adjustment) batch execution. |
38454974 | Upgrade scripts affected by Groovy 3.0.7 Upgrade to 3.0.17 [FW 4.5.0.2.0/C1 2.9.0.2.0] |
38669600 | MDM startup failure after upgrade of hibernate from v4 to v5 - MDM 2.5.0.2.0 version |
38645410 | Timeline zone displays all device events when no current device is installed for the selected service point |
38454995 | Upgrade scripts affected by Groovy 3.0.7 Upgrade to 3.0.17 [FW 4.5.0.2.0/X1 2.9.0.2.0] |
37878277 | MV90 SGG Native Upload job hangs/fails when there is a blank device id in one of the records |
37956225 | The Route Management zone is displaying duplicate SPs |
37973512 | Cross Installed Meter - Swap Meter throws, Device cannot be installed at the Service Point as a device is already installed for the install Date/Time, exception when multiple install events occurred for single service point |
37708243 | Unable to Delete Service Point |
37734704 | Error thrown on initial bills with non-interval scalar start date/time only for 30 minute dvc cfg POST 37195438 Gas Day Enhancement |
38073044 | Active Usage subscription For Request Orchestrator should be identified by SQL Zone |
37828837 | UT errors when rate change occurs on the first or last day of the UT period |
38198074 | Base Zone Scalar Readings are trimming reading value after two decimals |
37681500 | "Service Point Type is Missing" Error when de-activating Service Point |
38078545 | On Device retire, the option to select or add a Status Reason is not available |
38235921 | MDM - Users are able to run scripts, even with read only permissions |
38272737 | Viewing IMDs is causing page freeze when attempting to load IMD |
38095947 | Usage Transaction Correction Processor Activity Is Not Created for Scalar Read |
38331540 | Increase Data Type of column PERIOD_SEQ_NUM from Number(3) to Number(5) affecting Usage Transaction Tables |
38340911 | Editing a Multi-Item Entry in Service Point Deletes All Other Records |
37935136 | Backport request: Incorrect Error Message When Editing Service History Effective Date Time |
