Savings Hub Pre-Survey
The Savings Hub Pre-Survey page welcomes customers to the Savings Hub experience, and tells them what they must do to get their personalized assistance program results.
The Savings Hub Pre-Survey page aims to make the customer aware that they could benefit from available assistance programs, and to entice them to take the survey.
Customers will get the Pre-Survey experience if they are accessing for the first time from a promotional banner or search of their utility's website (or if they previously started their survey but never completed it). However, if customers access the Savings Hub from a marketing module promotion in their Email Home Energy Report or Home Energy Report, then they bypass the Pre-Survey and are directed to the first question of the main Savings Hub Survey.
Continue as a Guest
Customers can take the survey and see its results without logging in by using the option Continue as a guest.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Header The heading tells the customer that financial assistance is available. Default: Find out if you’re eligible for financial assistance |
Optional Choose one of the following:
Subheader The subheader calls attention to how the customer can get started. Default: Here’s how to get started: |
Getting-Started Steps Brief instructions that tell the customer what they need to do to get their survey results. Default:
| Survey Button The footer of the page includes a Begin Survey button that will redirect the customer to the Savings Hub Survey page. Default: Begin Survey |
User Experience Variations
The user experience varies for customers depending upon their service types, available data, costs, and locale. Note that the following list indicates the primary user experience variations, not all possible variations.
Unstarted Survey
Customers who start the survey, leave, and return to it later will see an altered Pre-Survey screen with the following variations:
- Survey Subheader: The subheader encourages the customer to finish the survey.
- Progress Indicator: A progress indicator bar appears to show how many total questions are in the survey and how many questions have been answered.
- Continue Button: A Continue Survey button is located just below the progress indicator. When the customer clicks the button, they are redirected to the Savings Hub Survey page.
- Getting-Started Steps: The instructions for the survey are relocated to the bottom of the page in case the customer wishes to review the steps.
