Active Status
The Active status flag is primarily used to organize tables that list the filters, datasets, calcs, and scenarios. A definition must be manually set to active or inactive; once it is set, you have the option to filter the tables on each page to only show active or inactive items. Customer production environments may be pre-configured to only show Active items.
If a procedure calls a specific version of a definition (using both ID and Sequence ID), an inactive status will be ignored.
