Heat Map Panel
The Heat Map Panel is available through the Distribution Planning and Operations module when displaying transformer data. The Heat Map panel displays a transformer’s load over time. The data can be viewed in chart (default) and gird formats.
- Chart view displays data points plotted by hours in a day and days. The y-axis displays hours in a day and the x-axis displays days. Each hour is colored according to the transformer load. The chart dynamically scales the load and compares the hourly value to the average load and color codes the values based on where a value is in the distribution of all values. Colors range from green (low values) to red (high values) with color blending for values in between.
Note: The Heat Map Panel’s boundary conditions can be configured.
Note: To view the chart data in a grid format, click the grid view icon.
- Grid view displays Heat Map panel data in a table format. Columns include the following and can be sorted in ascending or descending order:
- Fact Name: The name of the data category.
- Date: The data and hour of the value.
- Value: The calculated load value, which corresponds to one hour blocks in the chart.
To change the Heat Panel view, click the chart and grid icon located in the top right corner of the panel.
Options
The Heat Map panel provides the standard drop-down lists with default values.
- Time-basis: Hourly
- Display Options: Average Hourly Load
