Run/Task Operations
The Run/Task Operations page provides an overview of the system performance data for runs and tasks. To view all in-progress runs or tasks, select the Active Only checkbox.
To view task information:
- Select the Task button. The page will update with Task type drop-down options.
- Select a row in the Task Logs table to drill down on the data.
- Do one of the following to manipulate the task log data tables:
- To view the task log detail information tables, click the Details button.
To view the summary log information tables, click the Summary button.
