Understanding XML Editors
Filters, Datasets, and Calcs are defined as XML that is stored in the metadata database. XML editors provide a user interface for creating these definitions and have the same basic structure:
Image Number | Element Name | Description |
1 |Tree View |
Note: Required fields are marked with a red asterisk. |
2 | Summary Pane |
The Summary Pane displays the content of the selected element, which may be overview data or fields for defining the selection. It also has a Create New button (for example, Create New Time Windows) to create a new element of the selected type. |
