Cancel or Restore a Storm Model
You may want to cancel a storm model that is in the Draft, Historic, or Archived state. When a storm model is canceled, it is still available from the dashboard, but it cannot be used in another storm model’s ERT calculations.
Alternatively, you may want to restore a storm model that has been cancelled. When a storm model is restored, it can be used in another storm model’s ERT calculations if it is not in the Draft state. If you restore a storm model to the Draft state, it must go through the approval process again before it can be used in another storm model’s calculations.
Note: Only administrators have permissions to cancel or restore storm models. See Storm ERT Roles and Permissions for details.
Cancel a Storm Model
- Log in to Oracle Utilities Analytics Insights.
- Click Explore > Storm > ERT. The Storm ERT dashboard displays.
- Search for and select the storm model you want to cancel.
- Click Cancel. The storm model state changes to Cancelled. When it is in this state, its data cannot be used for another storm model.
- Search for and select the storm model in the Cancelled state that you want to restore.
- Click Restore. The storm model state changes to Draft or Historic depending on its original state.
