Data Panels
The Explorer data panels present information for a selected object based on its object type. Similar to other panels within the system, data panels can be expanded and collapsed using the triangle toggle button located to the left of the panel title bar. You can reorganize the panels by clicking and dragging the tile bar of a collapsed panel into the desired location.
You can save your personal panel configuration—including panel order, facts, chart type, and interval—by selecting Save Panel Configuration at the bottom of the page.
In this section:
