Export Data Tables
Data files can be exported to JSON, XML, and CSV formats.
To export a data table:
- Click the Export icon and select the desired format (JSON, XML, or CSV).
Select the maximum number of entries you want to export from the Limit drop-down.
- Click Download.
Data Table Column Descriptions
The following are descriptions of the columns shown on the data table. You can sort columns in descending or ascending order.
| Column Name | Description |
| Point Type Code |
Codes that represent the point type. For example, the Point Type code for Electric Meter is EM. Point Type Codes will vary by implementation. |
| Point Lookup | Constructed from the
Point Name by replacing spaces with a hyphen and lower case letters with capital
letters. For example, if Copy then Copy |
| Point Name |
A unique identifier. It is either the asset number (provided by the utility) or it is created using information about the point. The Point Name will vary by implementation. |
| Point Tag |
An asset number assigned by the utility. The Point Tag allows additional information to be stored for a point. Unlike Point Lookup or Point Name, Point Tag does not have to be unique, which means searching for a Point Tag can result in multiple matches. |
| Date | The date the value was recorded. |
