Monitor Menu
The Monitor menu provides access to the Queues, Database, Cluster, Distributed FS, and Nodes features.
Queues
The top section of the Queues Monitor contains the following elements:
- Refresh Seconds: Enter the number of seconds before the system information updates.
- Get Data: Retrieves system information.
- Countdown timer: Displays a graphical representation of how soon the displayed information will refresh. The gray bar decreases in size showing each second that has elapsed.
Note: When the data in the table refreshes, there is a brief yellow flash to indicate the change.
Display Area
The display area shows a matrix of information about the server’s queues.
- Each field in the table displays the number of processes that are Active, Waiting, or Buried:
- Active: The number of processes that are currently running.
- Waiting: The number of processes that are on hold or pending their dependencies to complete.
- Each column in the table displays the type of process. For example the image above is divided displays Fact Audits, Runs, and Tasks.
- Each row in the table displays the server node that is processing the information.
