Transaction Log
Whenever transactions are created, they generate an associated log within the system. This page allows you to search for and view related information.
Fields and Buttons
The following elements allow you to search for logs matching criteria:
  • Transaction ID: The transaction’s system-generated, unique identifier.
  • Get Logs: Initiates a search for logs matching criteria set in the field.
Data Table
The data table contains the following elements:
  • Transaction ID: Transaction’s system-generated, unique identifier.
  • Message Type: Log’s system assigned type.
  • Log Description: Additional information that describes why the log entry was created.
  • Create Time: Date and time that the log was generated.
Back to Top
