Filter Results Dashboard
The Filter Results dashboard displays the data defined in the Filter elements. The dashboard is configured to show data relevant to the selected role and type. For example, depending on the entity type and filter settings, filter results for an electric meter could display data for the meter ID, meter status, rate, and address where the entity resides or was collected. See Creating Custom Filters for more information about filter types.
Explorer filter results pane displaying data points identified by the filter settings
Module and Role Filter
You can use the Role drop-down to select a new role based on available modules.
Using modules and roles
The roles available to you depend on the module that has been implemented and your assigned groups, which control permissions including what functions are visible. The following table lists the default core modules and their associated roles.
Module Role
Meter to Bill AMI Deployment
Billing
Meter Operations
Safety
Revenue Protection Revenue Protection
Distribution Planning and Operations Distribution Planning
Demand Response and Energy Efficiency Demand Response
Energy Efficiency
History Panel
You can use the History panel, located on the right side of the page, to quickly access recently viewed meters for the current session. When you sign out and sign back in, the History tab will not display entities accessed from the last time you signed into the tool.
Navigation and Export
You can use the pagination controls to navigate the Filter Results list when there is more than one page of results. In addition you can use the Export icon to export data tables.
Back to Top
