Create Definitions With XML Editors
Filters, Datasets, and Calcs are defined as XML and stored in the metadata database. XML editors provide a user interface for creating these definitions and have the same basic structure. To access the XML editor from the data table click XML Editor on the row of the filter, dataset or calc you want to edit.
| Image Number | Element Name | Description |
| 1 |Tree view |
Note: Required fields are marked with a red asterisk. |
| 2 | Summary pane |
The Summary pane displays the content of the selected element, which may be overview data or fields for defining the selection. It also has a Create New button (for example, Create New Time Windows) to create a new element of the selected type. |
