Revert a Storm Model
If you need to edit an estimated restoration timeline (ERT), but the storm model is in an Approved or Cancelled state, then you can revert the storm model to a Draft state to make edits. You can then approve the storm model again, thereby restoring it for use in other storm model ERT calculations.
Note: Only administrators can revert storm models. See Storm ERT Roles and Permissions.
Warning: When you revert a storm model from an Approved state, you will lose any edits you have made to the workplan.
  1. Sign in to Storm ERT.
  2. From the Storm ERT dashboard, search for the name of the approved or cancelled storm model.
    Note: By default, storm models in a Cancelled state do not appear on the dashboard. You can display cancelled storms by clicking the States filter and selecting Cancelled.
  3. Click the name of the storm model to open it.
  4. Click Revert to Draft.
The storm model state is changed to Draft, and the ERTs can be edited.
