Create Custom Filters
You can create and save custom filters using the Advanced filter. You can reuse custom filters and export their results.
To create a custom filter:
  1. From the Filters section, click the More Filters and then Advanced. Click Create New Custom Filter.
    creating a custom filter
  2. Enter a descriptive filter name in the Create Filter field.
  3. Click in the Fact field. A Keyword Search field and a list of facts you can select from will appear.
    Fact Category Descriptions
    Fact TypeDescription
    MetricAllows you to specify a value or range of values of consumption-related data.
    EventAllows you to search for specific types of events in the selected time window. Events may be actual or derived from core calculations.
    ListAllows you to search for objects belonging or not belonging to a list (algorithm result).
    AttributeAllows you to search for numeric or text attributes associated with the object.
    RelationA standard relation, such as electric meter to premise, or a segment derived with an algorithm.
  1. Do one of the following to set the Value. To search for data:
    • That matches a specific value, select = from the Value drop-down and then enter the value in the value range field.
    • Greater than a specific value, select ≥ from the Value drop-down and then enter the value in the value range field.
    • Less than a specific value, select ≤ from the Value drop-down and then enter the value in the value range field.
    • Within a specific date range, select <> from the Value drop-down and then enter the date range in the value fields.
  2. Do one of the following to set the date range:
    • To select the date range using calendar days, select a date range for the data from the Dates fields.
    • To select a relative date (for example, one day, three weeks, and so on) click in the first date field to select a start date and do the same for the to date to select dates from a calendar.
      Selecting dates for custom filter
  3. If applicable, click the + button next to the calendar date fields to add an additional line of filter facts.
  4. Click Save.
Your new filter will appear as an option in the Filter Name drop-down of the Advanced filters section.
View Custom Filter Criteria
To view custom filter criteria:
  1. Open the Advanced filter and select My Custom Filters from the Category drop-down.
  2. Select the custom filter name from the Filter Name drop-down and click Apply. The table will refresh and apply the filters.
Edit Custom Filters Criteria
You can delete your custom filter or edit the criteria for it by clicking Edit above the Filter Name drop-down.
Back to Top
